Author Topic: Fair Price on Limelight Pulse?  (Read 16204 times)
Kalamity
« on: February 08, 2010, 03:10:45 pm »
Hi gang!  I'm wondering if $7500 is a fair price for an '09 Limelight Pulse.  It would include spa, cover, lift (my choice of 3), smart step (the larger non-slip type), sub panel, UV Ozone (what is the CD Ozone?), Stainless Steel Handrail (for my 82 yr. old mom), Silk Balance, Watercare Pkg., In Home Orientation, Delivery & Normal Setup.  Thanks.
Re: Fair Price on Limelight Pulse?
« Reply #1 on: February 08, 2010, 03:46:05 pm »
They are both ways of adding ozone to the water. The CD standards for Corona Discharge, and I believe its considered a more efficient method.  UV stands for ultra-violet which is considered the less efficient method. I don't know if one type lasts longer than the other.
Kalamity
« Reply #2 on: February 08, 2010, 04:28:24 pm »
Thanks, wmccall.  How does the price sound to those in the know?
« Reply #3 on: February 08, 2010, 05:07:55 pm »
If you're getting a Pulse spa for $7500 (lets consider delivery/setup, cover, water care kit, standard) with the addition of steps, lifter, subpanel and UV ozone I think that's a pretty good deal though I would prefer the CD ozone. Since most everything in life is negotiable (and certainly a spa purchase is) I'd try to get them to upgrade the ozone (even if I had to settle part way by taking the simpler steps) but otherwise it sounds good.
« Last Edit: February 08, 2010, 05:09:40 pm by Spatech t.u.o. »
« Reply #4 on: February 08, 2010, 05:46:36 pm »
 We looked at bringing in the silk balance chem system, in the end we felt it was going to be to expensive for the consumer compared to NAt 2 and chlorine/shock .
Kalamity
« Reply #5 on: February 08, 2010, 06:00:35 pm »
Thanks, JacuzziJim, I have to agree with you, but I thought I'd try it out just because it was offered originally.  Salesman also agreed to give me the CD Ozone.  It's all a learning curve.  Ummm... how does one tell if they have a CD Ozonator vs a UV Ozonator?  Now if only the snow gods would go on vacation then I could get my concrete pad mud jacked.  Does it matter how long you wait after mud-jacking before you set a tub on top?
You're all very helpful to us newbies.  Thanks.
« Reply #6 on: February 09, 2010, 11:02:08 am »
By looking at the unit itself where it should state CD or UV. They'll have to install it when the spa is delivered so just ask them to show it to you. The spa manual will tell you yearly to run some vinegar through the ozone system to clear out deposits so just tell them you want to see it so you know where it is.
« Reply #7 on: February 10, 2010, 11:29:39 am »
I have not been pricing tubs in quite a while, but that sounds like a good value compared to some I've heard. Its definitely not a grossly inflated price.
« Reply #8 on: February 16, 2010, 10:45:01 am »
There are CD ozone units which are real inexpensive and are designed to last about a year (with 24-hour use) and then be replaced. Some of these units can be purchased on line for less than $100 dollars.
The HotSpring Freshwater III system costs more but lasts longer.
Just sayin' ...
