Author Topic: older tiger river hot tub controller issue  (Read 3263 times)
tennesseestargazer
« on: November 27, 2009, 10:51:01 pm »
I have an early 90s, 3 person, tiger river hot tub. From time to time the controller will trip out. It's not the ground fault tripping. I have to turn the temp control all the way off and then back on to reset the controller. What could be causing it to trip out? I'm going to wire an LED into the circulation pump to see if it's shutting down when the controller trips out. I know the heat does. It is so agravating to go to get in the tub when you have a sore back and find the water is cold!!!!!
Re: older tiger river hot tub controller issue
« Reply #1 on: November 30, 2009, 09:40:15 am »
Welcome to the forum.  Great user name.
tjr
« Reply #2 on: December 01, 2009, 07:27:30 pm »
Flow switch needs to be replaced if circ pump is working properly
Peteyboy
  • 1991 HotSpring Classic - Tech since 1987
« Reply #3 on: December 02, 2009, 09:26:50 am »
Turning down and up the thermostat is a high limit reset for the Older Tigers. Could be a couple things: Low flow from circ pump - pull out the filter. A bad water check valve - should open and close completely when turning the jets on and off (it's right in front by the jet pump). I don't know if a bad flow switch would trip the high limit but, as suggested, it could be a culprit.
spas are electrical devices and can be dangerous to repair - please use this advice at your own risk
