Brand Specific Forums
Marquis Hot Tubs
Spa Purge ok for Marquis Epic?
Pages: [
2
Topic: Spa Purge ok for Marquis Epic? (Read 10867 times)
Junior Member
on:
October 28, 2009, 12:45:02 pm »
Last Edit: June 25, 2013, 11:04:16 am by .
on:
Bonibelle
Global Moderator
Ultimate Member
'05 Marquis Epic
Re: Spa Purge ok for Marquis Epic?
Reply #1 on:
October 28, 2009, 04:03:21 pm »
I think you should first access how bad your tub really is. Is the water green or really gross? If not, you can probably just shock really well and run your tub to clear out the contamination. That would allow you to leave your filters in place in the event that there would be any plastic like you are suggesting.
So if the tub is not grossly contaminated, you probably don't need the spa purge..but that is just my thought. If you just sanitize with shock you may want to change your water when you are sure the "goobers" have been killed (maintain a high bromine level)
When the tech comes, you could ask what he thinks you should do. He will probably have to have his hands in the water to do the repair...so he will know if it warrants spa purge..
Let us know how it all works out.
Bonibelle
Global Moderator
Ultimate Member
'05 Marquis Epic
Reply #2 on:
October 31, 2009, 12:44:58 pm »
So they should have fixed your spa yesterday, right? How did that go?
Junior Member
Reply #3 on:
November 01, 2009, 03:35:20 pm »
Last Edit: June 25, 2013, 11:03:00 am by .
Bonibelle
Global Moderator
Ultimate Member
'05 Marquis Epic
Reply #4 on:
November 01, 2009, 06:07:09 pm »
Drmac, If I had this situation, I think I would be writing to Marquis. Just stuffing that old busted up foam back in is not a great idea. they make foam that you can spray and that is what he should have done. And if there is still all that moisture after two weeks, I also wonder if it will ever dry out properly... how could it sealed up inside of the shell with all that foam? You need to have this addressed before you have more problems.
The tech might be inexperienced, but that is not a reason to accept this kind of service.
Hello....Marquis guys..what's up with this? This is NOT what I have experienced from Marquis and not what I would expect at a time when the hot tub industry is floundering..
Junior Member
Reply #5 on:
November 02, 2009, 01:26:50 pm »
Last Edit: June 25, 2013, 11:02:48 am by .
Bonibelle
Global Moderator
Ultimate Member
'05 Marquis Epic
Reply #6 on:
November 02, 2009, 01:51:52 pm »
That's good news...
MarKee
Full Member
Reply #7 on:
November 03, 2009, 07:04:21 pm »
It's unfortunate that this happened and I think your spa is going to be just fine. In all fairness, I don't think it's right to criticize Marquis for service that is performed by an independent dealer. If you bought a Mercedes and you had a problem with it, would you call up the factory that it was built at, or would you take it to the local dealer?
If the regional rep is going to stop by and take a look at your spa, I would say that's excellent service.
Every part of your spa is designed to resist water. The foam will dry and it has special anti-mold/mildew agents impregnated in it. The structure of your spa is also going to be completely fine. Think of a cedar wood deck that is exposed to water a majority of the year in a wet climate. It will take years and years for that deck to show any signs of rotting. The cedar in your spa was only exposed to water for a few weeks and it will dry. On occasion things break, even on the best built products in the world, that's what a warranty is for.
By the way, it sounds like you got an out of this world price on your spa.
Last Edit: November 03, 2009, 07:18:44 pm by MarKee
Ultimate Member
Reply #8 on:
November 03, 2009, 08:27:51 pm »
"By the way, it sounds like you got an out of this world price on your spa."
Maybe that is why the service sucked.
Markee, you know as well as I do that when a foam dig is done, the proper procedure is to refoam, not stuff in the wet foam that was removed. At least with Hot Spring. Maybe Marquis has a different procedure.
Zep
Senior Member
Cal Spas SQ92 Dallas-Texas
Reply #9 on:
November 04, 2009, 07:07:04 am »
"I had a motor/pump assembly replaced at the same time"
why was that needed on a one year old spa?
Junior Member
Reply #10 on:
November 04, 2009, 12:59:51 pm »
Last Edit: June 25, 2013, 11:02:25 am by .
MarKee
Full Member
Reply #11 on:
November 04, 2009, 02:57:40 pm »
It's strange that they replaced the pumps. The store I work at has sold 100s of spas with this same pump without a single failure.
I'm glad it sounds like everything is going to get taken care of.
Junior Member
Reply #12 on:
November 04, 2009, 05:28:38 pm »
Last Edit: June 25, 2013, 11:02:35 am by .
MarKee
Full Member
Reply #13 on:
November 04, 2009, 07:44:09 pm »
They changed the color of the motor a few months ago, but it's the exact same pump.
Is the rep in your area Jason? He's a really good guy.
Junior Member
Reply #14 on:
November 04, 2009, 09:19:59 pm »
Last Edit: June 25, 2013, 11:02:11 am by .
Reply #14 on:
Pages: [
2
Marquis Hot Tubs
