Author Topic: Jet Removal  (Read 2676 times)
benalexe
Jet Removal
« on: May 23, 2009, 09:03:26 pm »
I have a question. Not sure if most spas are like this or it is just my thermospas.  The jets in my spa can be removed. They have an outer ring which if you twist it you turn the flow off to the jet if you twist it more then pull the jet comes out.  My problem is they are so hard to get a good grip on to turn them.  Do you guys have any suggestions?
Jet Removal
Re: Jet Removal
« Reply #1 on: May 24, 2009, 06:32:41 am »
I have a thin piece of rubber that was designed as an air to opening jars. I occasionally use that.
Re: Jet Removal
