Author Topic: 12 volt connection  (Read 2534 times)
rcwinter
12 volt connection
« on: February 03, 2009, 11:09:02 pm »
I have a Cal Spa Avalon A857L hot tub and just purchased a ThermoSpa Towel Warmer Compartment. The towel warmer cabinet requires 12V DC.
Is there a 12V DC connection within the control system to hook up the towel warmer?
12 volt connection
IDW
Re: 12 volt connection
« Reply #1 on: February 08, 2009, 05:41:20 pm »
probally not The transformer on the board will be AC volts. You probally could hook your own transformer into one of the high voltage conections
Markus
  • HS Vanguard 2005
« Reply #2 on: February 08, 2009, 09:58:31 pm »
I'm sure that there could be a 12 volt power supply on the circuit board...but it's definitely not designed for use as a source for external equipment.
What you need to find out is: how much current or watts is required for towel warmer to operate and then you could probably purchase a 12 volt power adaptor with the proper current or wattage requirement.
« Last Edit: February 08, 2009, 09:59:45 pm by Markus »
