Original
whats your number???
Pages: [
2
Topic: whats your number??? (Read 7235 times)
benalexe
Full Member
on:
November 13, 2008, 08:44:41 pm »
My wife is not that into the hot tub. For my birthday I told her that I wanted her to go in with me. I have not used the tub that much because it is not as fun alone.
Anyway, I am still new to hot tubing and since my wife is always cold I put the heat up to 104. I went out and felt it and it felt warm but definitely not hot.
We then got in the tub and we were warm.... comfortable.... (maybe even a slight chill on upper body) Within 10 minutes of being in the tub the warmth turned into we were so hot. It was weird because the water did not feel that hot but then I guess it took a few minutes for our body temp to go up.
We soaked for a while drank a glass of wine and it got to a point that we were too hot and had to get out. The entire evening we were both sweating. So 104 was definitely too hot.
So I ask you what is your #?? PS. I live in the northeast. it was about 40 degrees when we went in.
My wife's biggest fear was that she was going to freeze when she got out. That was not the case. It got me thinking.... We can probably lower the heat in the house every night by just going for a hot soak!
on:
Micah
Full Member
Re: whats your number???
Reply #1 on:
November 13, 2008, 08:52:03 pm »
I live in S. California, so the outside temp is a little different. The low tonight is 62. We go in at 102- 103. We stay in for two cycles of the jets (40 min.)
cedar tub
Junior Member
Reply #2 on:
November 13, 2008, 11:13:52 pm »
We live in the Atlanta area and our temps were going into the 30s at night about two weeks ago (30 a couple of times), but the last week, we've been in the 40s at night. I've kept the tub at 99-100F and it's been nice. Our winter weather is just plain crap. When precipitation moves in, it normally stays above freezing and we won't get many opportunities to enjoy it on a snowy night. The weather can go into the teens at night and I've seen single digits a few times since moving here. It does snow occasionally and I hope we get to use the tub if that happens this year. I'm sure we'll crank it back up to 102 in late December or before.
I've got wood and it's 5ft x 4ft
Zep
Senior Member
Cal Spas SQ92 Dallas-Texas
Reply #3 on:
November 14, 2008, 09:38:42 am »
in Dallas I keep mine in the 99,
100
, maybe 101 range depending on outside temp of course
benalexe use your "cool off" seats more and you won't get the over-heating as much
Last Edit: November 14, 2008, 09:39:06 am by Zep
Global Moderator
Mentor Level Member
Reply #4 on:
November 14, 2008, 09:44:08 am »
5 years of using it almost every night, we vary the temp quite a bit. Most of the time its 20-30 minutes in the evening with the wife and I and its as much social as therapy so that is usually 102. When it is below zero you can stay in a 104 longer. Summer evenings 101. After a day of skiing or Curling, its definitely 104 with the jets blasting.
NE-Phil
Senior Member
Marquis Reward '05
Reply #5 on:
November 14, 2008, 10:21:51 am »
I'm in upstate NY and we keep the temperature at 101° F all through the Fall and Winter. We have tried it warmer but, for us, it gets to be too uncomfortable to stay in for any length of time.
Phil
LStoner
Junior Member
Reply #6 on:
November 14, 2008, 11:15:21 am »
Our number is 96. Yea, I know that's low. We are in Central, IL. Our hot tub is indoors, so I think that may make a difference. And just like you said, doesn't feel real warm when you first get in, but after about 30 minutes we're boiled.
soak-king
Full Member
Where did that dang duck go anyway?
Reply #7 on:
November 14, 2008, 12:08:24 pm »
Here in southern Texas I have mine set at 102 most of the year and then UT3 when it gets cold. (below 40)
Last Edit: November 14, 2008, 12:09:49 pm by soak-king
dax
Full Member
'07 Sundance Cameo
Reply #8 on:
November 14, 2008, 12:44:12 pm »
I'm in eastern PA. Right now the tub is at 102*. During the summer, it's 100*.
benalexe
Full Member
Reply #9 on:
November 14, 2008, 09:25:54 pm »
Do most of you feel a little cool when you first get in?
ndabunka
Full Member
2003 Jacuzzi J370 Platinum/Coastal Grey Synthetic
Reply #10 on:
November 14, 2008, 11:32:55 pm »
102 about 90% of the time. The only time I reduce it is if I know (in advance) that my 5 year old is going to be going in and then it's to 100. Live in NC
Sgt. Schultz
Junior Member
Reply #11 on:
November 15, 2008, 02:40:08 pm »
The wife enjoys 104
I prefer 102
We compromise on 104...
East_TX_Spa
Mentor Level Member
30 Year HotSpring Spa Dealer
Reply #12 on:
November 15, 2008, 04:10:50 pm »
106, pick up sticks.
Term
Chad
Senior Member
2006 Jacuzzi J-345
Reply #13 on:
November 15, 2008, 05:00:14 pm »
108, Make 'em faint.
Chad
Last Edit: November 15, 2008, 05:01:31 pm by WHY_NOT
East_TX_Spa
Mentor Level Member
Reply #14 on:
November 15, 2008, 05:27:33 pm »
109'll burn yore behind...
Reply #14 on:
Pages: [
2
Original
