Author Topic: Envoy Weir Door Problem  (Read 2401 times)
tonyp
  • Soaking in a HS Envoy!
« on: November 01, 2008, 11:51:23 am »
The Weir door on my Envoy came off track.  Around that time, I noticed a little white "pin" by the tube.  I assumed that this pin is what kept the door from coming too far up.  There are 2 holes in the track about an inch apart.  Assuming I am right, which hole does the pin go it?
Gomboman
  • My Pride and Joy
Re: Envoy Weir Door Problem
« Reply #1 on: November 01, 2008, 12:26:32 pm »
I had a problem with my door coming off also. The tech put a screw into the right lower hole to keep it from coming out.
tonyp
« Reply #2 on: November 02, 2008, 05:35:40 pm »
I used an automotive upholstery pin.  A little plastic pin $0.23 at the local hardware.  I put it in the top hole.  I'll move it to the bottom.  Thanks.
