Author Topic: Accidently Used Soft Water  (Read 5349 times)
Guelphgirl
« on: October 13, 2008, 04:33:21 pm »
 :-[ :-[Drained and refilled tub today. Unfortunately I forget to bypass the water softener and filled the tub with soft water. Should I drain the tub and refill or will it be OK.
The_real_Clown_Shoes
Re: Accidently Used Soft Water
« Reply #1 on: October 13, 2008, 06:39:36 pm »
You should be okay so long as you add some Calcium Hardness Increaser.
Neptuner
  • My only tub foam
« Reply #2 on: October 13, 2008, 11:43:59 pm »
I would drain about half and refill with unsoftened water.
« Reply #3 on: October 14, 2008, 07:44:48 am »
Unless if gets really foamy leave it alone.  Its been said here the only reason people recommend adding any calcium is a carry over from pool mantenance. I don't think soft water is any harm to hot tub materials.
« Reply #4 on: October 14, 2008, 08:56:15 am »
Gonna dissagree with the big kahuna here...
Soft water can be corrosive to the equipment and WILL cause foaming. It's an easy  adjustment with a calcium hardness increaser. Don't wait for problems to start but instead, make the adjustment now.
Do you know what your hardness reading is?
Hillbilly Hot Tub
« Reply #5 on: October 15, 2008, 12:33:53 pm »
I agree with Steve, I will add that I do not pull the CH up as high as suggested though. I keep it at 100-150.
« Reply #6 on: October 20, 2008, 12:09:55 pm »
Never hesitate to do so.  I know my water is on the softer side, but probably in the range that Hillbilly suggested.
