Author Topic: Cover Clips  (Read 5363 times)
txwillie
Cover Clips
« on: September 10, 2008, 08:14:35 pm »
Is there an easy solution to the broken plastic male part of the cover clips, the part that clicks into the receptor screwed into the side of the outer cabinet? I have a Sundance, but I think these are pretty universal regardless of brand. They were identical on my former Marquis. Thing is, the clips are one piece and the canvas straps are threaded through the sewn straps, therefore not removable or replaceable. These little clips suffer UV degradation and break in short order. My dealer said the only fix is to unstitch the straps, thread on new clips and sew the straps back.  That seems plum stoopid to me. Any ideas? The only thing I can come up with is buy new clips, cut them and slip them on to the loops in the straps.
Ike seems to be headed to Austin and I think I need to secure the cover as best I can. Any help will be greatly appreciated.
txwillie
Cover Clips
Re: Cover Clips
« Reply #1 on: September 10, 2008, 08:40:09 pm »
Your idea is what we and our customers do.
You might want to get a set of wind straps also, with Ike coming.
txwillie
Re: Cover Clips
« Reply #2 on: September 10, 2008, 09:03:58 pm »
Thank you hottubdan. What 'zactly are wind straps? is this something my dealer might have? I'm not sure I have time for web purchase and then delivery.
Probably over reacting at this point, but the latest shows C4 coming ashore C2 slightly inland and C1 or TS by Central Texas
txwillie
Chad
  • 2006 Jacuzzi J-345
Re: Cover Clips
« Reply #3 on: September 10, 2008, 10:40:04 pm »
You don't have to un-sew the straps. You can buy new clips(your dealer should have some readily available) and then make a small cut into the back end(where the strap attaches to it) with a hacksaw. Make sure to cut it at an angle for added strength and then simply thread the strap in to it. Or you could just order these replacements at the link below that already have the cut made. The only downfall is that the cut seems rather large and is not at an angle.
http://www.easyspaparts.com/products.asp?cid=6
« Last Edit: September 10, 2008, 10:41:21 pm by WHY_NOT »
webboy
  • hey bub
Re: Cover Clips
« Reply #4 on: September 11, 2008, 11:03:23 am »
Here's a picture that should help
txwillie
Re: Cover Clips
« Reply #5 on: September 11, 2008, 07:16:06 pm »
Thanks guys. I picked up a pack of 4 today and will get the Dremel out in a bit and get after it. Fortunately for me and Austin, Ike is taking a different path. The folks in Galveston, Houston and Beaumont aren't going to have it so easy. Keep them in your thoughts.
txwillie
Re: Cover Clips
« Reply #6 on: September 12, 2008, 10:47:54 am »
I've never heard of replacement clips that need to be cut. I've only seen the ones like webboy posted a picture of that you just slide the material into...  :-?
Hillbilly Hot Tub
Re: Cover Clips
« Reply #7 on: September 12, 2008, 11:42:09 am »
All the ones we have ordered have to be cut, I have not seen the precut ones before :-?
Either way it all works out the same in the end without having to sew...I hate sewing!
webboy
  • hey bub
Re: Cover Clips
« Reply #8 on: September 12, 2008, 12:17:24 pm »
I had to cut the one above. I just did this for my own tub (opened my tub without undoing the back straps, snap, crackle, pop but no rice crispies)
Here are the steps
To replace the male clip portion of the cover lock:
Cut a 6mm. notch at an angle out of the center of the clip as shown in the picture. Slide the vinyl cover strap into the notch .
The vinyl strap will cover the notched out area and will not compromise the strength of the clip.
Vanguard
Re: Cover Clips
« Reply #9 on: September 12, 2008, 12:18:31 pm »
txwillie
In a large storm like a Hurricane, you might be just as well off removing your cover.  Yes, your spa might get dirty, but your cover won't get destroyed.
stuart
Re: Cover Clips
« Reply #10 on: September 12, 2008, 02:06:57 pm »
As intimidating as it seems, cutting the thread at the seam of the fold on the clip and re-sewing it is pretty easy for a customer. You just need some heavy thread/dental floss and a large needle or Awl.
If you have a Tandy leather store in town you can get the stuff there or Hobby Lobby.
Otherwise a windstrap is an easy solution and you don't have as many clips to reclip when you get out.
Re: Cover Clips
« Reply #11 on: September 15, 2008, 11:01:16 am »
Hopefully, these high-tech, pre-cut clips make its way to the US one day soon! ;)
webboy
  • hey bub
Re: Cover Clips
« Reply #12 on: September 16, 2008, 01:24:38 pm »
If you promise to buy them (at a premium), I'll quit my day job and start cutting.  :D
Re: Cover Clips
