Author Topic: Need creative ideas for hanging my clock  (Read 12196 times)
Bonibelle
  • '05 Marquis Epic
« on: August 02, 2008, 01:29:00 pm »
I finally found a clock/thermometer combo that I really like for outside. I want to hang it so that we can see the temperature from the pool and hot tub. So that limits me to one wall and it is stucco. I won't drill through the stucco...don't want water to get under it and cause it to crack. Has anyone found a creative idea for hanging something like this without drilling into the stucco? I was even thinking of hanging it from the soffit somehow, but not sure if it would work.  :-/
Re: Need creative ideas for hanging my clock
« Reply #1 on: August 02, 2008, 02:26:50 pm »
How heavy are they?
Where I work they hang various artists paintings/pictures on commercial picture hangers.
If the soffit is wood - maybe a "T" of 1x2's screwed into the soffit and hanging down with the clock and thermometer hanging from it. If you paint it the color of the soffit and wall it should almost blend in. Or have it come from the ground if possible.
They sell those 3M hangers, the ones that you pull down to remove - don't know how well they would stick outside or on stucco.
I'll keep thinking though.
« Last Edit: August 02, 2008, 02:28:08 pm by Vinny »
fdegree
  • 2007 Sundance Optima
« Reply #2 on: August 02, 2008, 04:19:55 pm »
Try your local hardware store where they stock glues and adhesives.  Although, with this kind of product, it could damage the stucco if you ever want to remove it later, so be careful.  It may not be too bad on your vinyl or aluminum soffit.  Some of the adhesives and "sticky" pads can heat up in direct sun light, thus losing their ability to hold weight.  So, watch out for that.
If you did decide to drill a hole into the stucco, you could fill the hole with caulk.  Then, before the caulk dries, insert the screw and caulk around the screw a little more.  This might help prevent any water from getting into the hole and behind the stucco.  Though I completely understand your hestiation to put holes into your wall.
Don't know what kind of ground cover you have around the pool and spa, but could you "drive" something into the ground...4x4 post, galvanized pipe, PVC pipe, etc.  Hang the clock on this and utilize it for other things too.  Such as, hooks or rods stuck to it to hang towels on or perhaps wind chimes...whatever comes to mind.
Bonibelle
  • '05 Marquis Epic
« Reply #3 on: August 04, 2008, 10:53:41 am »
Thanks for the ideas guys, I went to the Home Depot and found my solution...
Here is the clock/thermometer just where I wanted it...No holes in the stucco and I 'm happy with the results..can you see how I did it?
Chad
  • 2006 Jacuzzi J-345
« Reply #4 on: August 04, 2008, 11:33:39 am »
There's a string hanging down from the soffit??
wewannahottub
  • Time for your Sponge Bath!
« Reply #5 on: August 04, 2008, 11:56:28 am »
[size=48]HERCULES HOOK???[/size]
 ;D ;D ;D ;D
« Last Edit: August 04, 2008, 11:57:12 am by wewannahottub »
The grass is greener on the other side because the bulls**t is better...
Bonibelle
  • '05 Marquis Epic
« Reply #6 on: August 04, 2008, 11:59:08 am »
Chad is right. I was able to squeeze a screw up in one of the little ridges of the soffit. Home Depot has this clear string..supposed to be able to hold 50 lbs..it worked really well because you have to walk right up to the wall to see it.  ;)..Now I have something new to add to my velcro, hot glue, duct tape collection  ;D
wewannahottub
« Reply #7 on: August 04, 2008, 12:03:23 pm »
Wow, I couldn't tell!!   :D  It is a nice clock/thermometer.  Did they have them with frogs?? :)
Bonibelle
  • '05 Marquis Epic
« Reply #8 on: August 04, 2008, 12:48:13 pm »
No frogs...this was a left over from a sale at Boscov's. I looked all summer for one with a large clock and small thermometer. So you like frogs?  I will have to share some of my friend's pictures with you.. ;)
wewannahottub
« Reply #9 on: August 04, 2008, 12:55:01 pm »
I LOVE frogs!!  Kiss enough of them and you find your prince, like I did!!  :-*
We were biking Saturday, and there were a whole mess of frogs in some standing water along the trail.  They were so CUTE!!  I have a frog that has found it's way to my little fish pond.  I am hoping he sets up home and finds a cute frog-mate.  I'll have to take some pix...
« Reply #10 on: August 04, 2008, 08:37:53 pm »
All this time I thought you were askin' us about hangin' a GLOCK.
 8-)
Mr._Bubbles
  • Tiger River Bengal-HP
« Reply #11 on: August 04, 2008, 08:51:22 pm »
I read it wrong too, that's all I'm going to say. :-?
It's all about da bubbles!
Mr._Bubbles
« Reply #12 on: August 04, 2008, 08:53:49 pm »
Sorry to get off topic, but there is a large frog living under the steps for my spa. :)
Bonibelle
  • '05 Marquis Epic
« Reply #13 on: August 05, 2008, 09:51:07 am »
Probably not a frog (unless he is soaking in your tub too)..but a toad. That's a good thing, he will eat bugs around your tub ;)
This is Mr Peepers...a spring Peeper that I rescued in March from my patio door..
wewannahottub
« Reply #14 on: August 05, 2008, 12:48:37 pm »
[size=18]AAAAWWWWW!!  HE'S SO CUUUTE!![/size] :) :)
