Author Topic: Draining methods?  (Read 2764 times)
kacrab10
  • 2004 Sundance Optima
Draining methods?
« on: June 29, 2008, 10:12:36 am »
If you open the drain on the side of the hot tub is there a method of hooking a hose to it or do most people drain by gravity with a hose?  Id like to be able to direct the drainage away from the deck and grass if I can. We ran the cleaning stuff through the jets all night now it's time for fun!
Draining methods?
Bill75
  • 2006 Grandee owner
Re: Draining methods?
« Reply #1 on: June 29, 2008, 10:28:30 am »
I use a hose whenever I drain:  my hot tub (Hot Springs Grandee) has 2 drain connections, and both are threaded for a standard garden hose.  If your tub doesn't provide threaded connections you can always buy a dewatering pump.  I have seen them online:  they are supposed to be faster than gravity drains and allow you to clean out all the "pockets" on the seats.
Bill
kacrab10
« Reply #2 on: June 29, 2008, 10:37:54 am »
when you open the drain doesn't the water just come pooring out? How do you get the hose on?  Sorry if this sounds stupid but we just got the hot tub filled and clean and I can't find information on line. We bought used.
Chad
  • 2006 Jacuzzi J-345
« Reply #3 on: June 29, 2008, 10:59:27 am »
Here's your spa's manual-
http://www.sundancespas.co.nz/files/NorthAmerican60HzPortableSpaManuals/04850ManRevC.pdf
benalexe
« Reply #4 on: June 29, 2008, 11:03:10 am »
I bought a sump pump. Much easier than unscrewing the side pannel and hooking up a hose.   I got mine refurb on eaby for like $40
kacrab10
« Reply #5 on: June 29, 2008, 11:14:21 am »
Chad I am dumber then I look!!!  Somehow I totally missed that HOW TO DRAIN YOUR HOT TUB!!  LOL.  Insert foot in mouth!
Thanks :-[
hot tub Frank
  • tiger river bengal
« Reply #6 on: June 29, 2008, 01:36:15 pm »
I just open up my valve and through the deck it goes.
kacrab10
« Reply #7 on: June 29, 2008, 07:59:22 pm »
I did it all by myself but it took forever!!! We have it refilled and it is heating last checked it was low 70's so still waiting to put the chlorine in!
