Author Topic: 06 GRANDEE PROBLEM NEED HELP PLEASE.....  (Read 6910 times)
Re: 06 GRANDEE PROBLEM NEED HELP PLEASE.....
« Reply #15 on: June 17, 2008, 02:08:54 pm »
  I pretty much know that, I was being a bit of a smart a--
You? No way! ;)
« Reply #16 on: June 17, 2008, 02:13:24 pm »
 Chlorine after use or every couple of days is what I suggest.
 Personally I think your green tint is coming from something else.  Speaking with my tech he seems to remember it was a case of to low or to high of PH.  Its been awhile since he had to deal with it, but he remembers raising or lowering PH and the green tint went away almost instantly.  You on a well system?   Or it could be something else??
 Asparagus??
« Reply #17 on: June 17, 2008, 02:16:14 pm »
You? No way! ;)
 ;D   Its good to laugh.     I mean that in a positive way!!
STEELMAN
« Reply #18 on: June 17, 2008, 02:34:07 pm »
WHEN I DO ADD CHLORINE ON THE WEEKLY MAINTENENCE, THE GREEN GOES AWAY BUT RETURNS WITHIN A WEEK OR SO....MY PH IS ALWAYS IN THE 7'S AND THE TOTAL ALK IS 120 OR LOWER.... THANX FOR THE HELP JIM....AND I DONT CARE WHAT EVERYONE ELSE SAYS ABOUT  YOU..J/K NOT ON A WELL SYSTEM BY THE WAY...JUST REGULAR CITY WATER IN SO CAL.
« Last Edit: June 17, 2008, 02:34:57 pm by STEELMAN »
« Reply #19 on: June 17, 2008, 02:40:53 pm »
  Thats a tough one sounds like everything is where it should be.  :-/
 The good news its nothing that should hurt you!!   Does a dose clarifier help at all, and does the cloudiness go away and the green stays?
« Reply #20 on: June 17, 2008, 04:22:13 pm »
Clarifiers can work well but often times are overused IMO. I think this is a case of sanitize properly first and then if any green tint happens I'd move to a clarifier.
« Last Edit: June 17, 2008, 04:56:51 pm by Spatech_tuo »
STEELMAN
« Reply #21 on: June 18, 2008, 01:32:27 pm »
CHECKED WATER YESTERDAY EVENING AND NO GREEN TINT....BUT THE WATER WAS A LITTLE CLOUDY.
I CHECKED THE PH AND TOTAL ALK AND THE ALK WAS HIGH???MY PH WAS 7.6 AND ALK 202. DOES ANYONE KNOW A WAY I CAN LOWER TOTAL ALK WITHOUT ADJUSTING THE PH TOO MUCH...THANX AGAIN
STEELMAN
« Reply #22 on: June 18, 2008, 06:23:04 pm »
bump
« Reply #23 on: June 18, 2008, 07:19:16 pm »
 Just leave the alk alone it will most likely come down on its own.
« Last Edit: June 18, 2008, 07:19:46 pm by Jacuzzi_Jim »
