Author Topic: Calculating deck supports to support a tub???  (Read 6923 times)
rubadubeh
« on: June 01, 2008, 10:00:26 pm »
I am planning to move my tub from its current location on a concrete slab to a yet to be built deck off my existing deck.  My tub is about 5000 lbs filled.
 I am unsure of how many deck peirs to use and was thinking that 6  x 12" piers below frost line depth should be enough but have no mathimatical skills to back that up.
 Where can I find this information or how can I figure it out.
 Thanks in advance.
jimmyb
Re: Calculating deck supports to support a tub???
« Reply #1 on: June 01, 2008, 10:05:27 pm »
This link will help, if you're using deck blocks...
http://www.deckplans.com/howtobuild/hottub/hottub01.html
« Last Edit: June 01, 2008, 10:05:56 pm by jimmyb »
rubadubeh
« Reply #2 on: June 01, 2008, 10:12:47 pm »
Thanks for the reply Jimmy!  Pretty unscientifc information but helpfull nonetheless.
 Just to clairfy I will be augering and pouring 12" sonotube piers.
 Regards,  Chris
Spiderman
« Reply #3 on: June 02, 2008, 09:17:52 pm »
Both my decks are floating decks.  I've never had a problem with either of them.  They are only about 28" inches high, and to me, a floating deck is the only way to go.  A lot less work than digging holes and dumping in cement.  Most decks I would guess are overbuilt because you'd have to be an engineer to calculate the load rating :o
Chad
  • 2006 Jacuzzi J-345
« Reply #4 on: June 03, 2008, 10:29:48 am »
 Thanks in advance.
This should help-
http://www.ideas-for-deck-designs.com/deck_load_capacity.html
