Author Topic: I spoke to soon  (Read 5085 times)
Skellman
  • There's more horses asses than there are horses!
I spoke to soon
« on: May 31, 2008, 07:49:08 am »
Good morning,
Well, after I posted yesterday that my water has been clear from the start, I arrived home after work to dirty water. >:(
I added some sani-chlor and ran it for an hour or so. Went to my sons graduation and came home to find it the same.
I added some shock and went to bed. Basically the same this morning.
The water is approximately 6 weeks old. And everything on the test strip is good.
What the heck happened?
Is this something that will take a day or so to clear up?
I spoke to soon
Chad
  • 2006 Jacuzzi J-345
Re: I spoke to soon
« Reply #1 on: May 31, 2008, 07:59:46 am »
When you say "dirty" water, do you mean it's cloudy. If so, some things you can do to rid the cloudiness are
-Add a larger than normal dose of dichlor. I'd shoot for atleast 10ppm FC.
-Clean filters
-Increase the amount of circulation
If you do all that Today and you still have cloudy water tommarow, add 1-2 ounces of clarifier.
« Last Edit: May 31, 2008, 08:02:54 am by WHY_NOT »
Mr._Bubbles
  • Tiger River Bengal-HP
Re: I spoke to soon
« Reply #2 on: May 31, 2008, 08:30:51 am »
If that does not work, just drain and refill.  Sometimes starting over is the easiest thing to do. Good Luck!
« Last Edit: May 31, 2008, 08:38:33 am by Mr._Bubbles »
It's all about da bubbles!
Skellman
Re: I spoke to soon
« Reply #3 on: May 31, 2008, 10:07:11 am »
-Clean filters
I'd say it has a brownish tint more than it's dirty.
Sorry to sound ignorant but, dichlor is the sani-chlor, correct?
I cleaned my filter last Saturday. I'll do it again.
I notice there is more foaming than in the beginning.
Thanks for the responses Chad and Mr. B.
Skellman
Chad
Re: I spoke to soon
« Reply #4 on: May 31, 2008, 12:02:57 pm »
I'm not too familar with the term sani-chlor, so I did a quick google search and only found one hit that related to hot tubs. It was product called Nature's Way Sani Chlor. I wasn't able to find the amount of available chlorine in it or the ingredients. Does your bottle have this info printed on it?
« Last Edit: May 31, 2008, 12:29:58 pm by WHY_NOT »
Mr._Bubbles
Re: I spoke to soon
« Reply #5 on: May 31, 2008, 12:20:10 pm »
I'm thinking this may not be dichlor, is this it?
http://www.hasapool.com/catalog/p-1.htm
« Last Edit: May 31, 2008, 12:22:31 pm by Mr._Bubbles »
Skellman
Re: I spoke to soon
« Reply #6 on: May 31, 2008, 12:23:49 pm »
That's the stuff.
I'm pretty sure it's a dichlor. The bottle reads "97% sodium dichloro-s-triazinetrione. Available chlorine-62%.
I put a capful in before my son's soccer game and turned everything on full. I just checked and it seems to be getting a little clearer.
Thanks again, Chad.
Skellman
Re: I spoke to soon
« Reply #7 on: May 31, 2008, 12:25:34 pm »
Sorry Mr. Bubbles. You must have sent while I was typing. Thanks to you as well.
It is the Nature's Way product Chad mentioned.
Chad
Re: I spoke to soon
« Reply #8 on: May 31, 2008, 12:28:36 pm »
No problem.
62% is really good. My Leisure Time - Spa 56 is only 55%.
Mr._Bubbles
Re: I spoke to soon
« Reply #9 on: May 31, 2008, 12:29:39 pm »
No problem, hope you get it figured out.
Skellman
Re: I spoke to soon
« Reply #10 on: May 31, 2008, 12:46:11 pm »
Let me ask this.
I just cleaned the filter again. When I put it back, I actually let the trapped air purge out as shown in the manual (which I just received). I could be wrong but, I notice the flow seems more noticable when the pump is on. Is it possible there was air trapped in the filter and for the last 4-5 days it wasn't filtering? When I cleaned the filter last weekend, I simply put it back in.
Vanguard
Re: I spoke to soon
« Reply #11 on: May 31, 2008, 12:52:51 pm »
That is a distinct possibility.
Skellman
Re: I spoke to soon
« Reply #12 on: June 01, 2008, 02:04:21 pm »
First,
Thanks again to Chad, Mr. B and Vanguard for taking the time to respond.
Indeed the problem was that the filter had air trapped in it. Thus, it wasn't filtering. The water is clear once again. ;D
I'm learning.
Now to get the pool ready.
Re: I spoke to soon
