Author Topic: Spa light  (Read 3353 times)
benalexe
Spa light
« on: May 26, 2008, 07:54:05 am »
Did anyone here purchase one of these?
http://www.hottubworks.com/cgi-bin/commerce.cgi?preadd=action&key=JJLSL24-1
Any reviews or comments would be great.
Spa light
Re: Spa light
« Reply #1 on: May 26, 2008, 09:10:09 am »
That type replacement bulb will work well on spas that have a simple on/off switch.  If your spa light dimms, you will not get satisfactory results.  There are other manufacturers that make this style light.
benalexe
Re: Spa light
« Reply #2 on: May 26, 2008, 11:55:11 am »
My spa has a dimmer so I guess it would not work right. Any alternates?
Re: Spa light
« Reply #3 on: May 26, 2008, 03:38:18 pm »
Your spa manufacturer may make a light that works with your model.  I know my Sundance spa has a dimming light but SD has a light that retrofits and works with my switch....but I have the same situation where an aftermarket light will not work correctly.
windsurfdog
Re: Spa light
« Reply #4 on: May 27, 2008, 10:55:19 am »
ben,
That same unit is in my tub.  I specified a multicolored LED light at purchase and that was the unit they installed.  The Balboa controller that controls my tub has a dip switch that allows the light to either be operated on-off or with a dimming function.  You might check your controller and see if the same is available.
BTW, I enjoy the ColorGlo though I rarely use the light unless guests are over or when adding chems after a night soak.  The red light is expecially good for allowing night skies to remain bright while one soaks with the light on.  There is another color change mode that cycles between blue, green and aquamarine that is pretty appealing also.  I like the product and its different functions.
Re: Spa light
