Author Topic: Lowe's 60 Amp Spa Disconnect Recalled  (Read 13293 times)
Swell-Tub
  • Scott
« on: May 20, 2008, 09:17:04 pm »
I went to Lowe's this evening to purchase a 60 Amp GFCI Spa Disconnect Panel. Lowe's is pulling them from the shelves and replacing them with 50 Amp Spa Disconnect Panels. All they could tell me is that the manufacturer are buying back all that are on the shelf. They are made by Midwest Electric Products Inc. and the part number is UG412RMW260P. I was able to travel up to the last Lowe's in Northern Las Vegas and buy one before they pulled them. I need 60 amp service if I want to run both pumps and the heater at the same time.
Anyone know what's wrong with them?
Scott  :o
« Last Edit: May 20, 2008, 09:17:50 pm by Swell-Tub »
2008 Jacuzzi J-470
ndabunka
Re: Lowe's 60 Amp Spa Disconnect Recalled
« Reply #1 on: May 20, 2008, 09:55:20 pm »
There are zoning regulations in many towns that require 60amp ONLY be installed by qualified electricians.  Therefore the only reason they may be pulling them is to stay within the confines of those regulations.  I do know that around here, we did not have the abliity to buy a 60amp GFCI from any of the large stores (Home Depot nor Lowes) when I did mine.
Spatini
« Reply #2 on: May 20, 2008, 09:59:56 pm »
Swell,
Thats the same panel I used on my j-480 and I also went with the 60 amp configuration, works fine and it also lets you add a smaller gfi for a 110 outlet.
Swell-Tub
  • Scott
« Reply #3 on: May 20, 2008, 10:04:56 pm »
Scott  :o
My electrician sent me to Lowe's because he couldn't find any thing larger than a 50 amp in the electric supply houses. Go figure.
Scott  :-?
2008 Jacuzzi J-470
Spatini
« Reply #4 on: May 21, 2008, 12:07:08 am »
You can also get a 60  amp from Spa depot, also very good wiring info/ help
http://www.spadepot.com/spacyclopedia/wiring-hot-tub-spa.htm
Skellman
  • There's more horses asses than there are horses!
« Reply #5 on: May 21, 2008, 04:16:44 pm »
I installed the Lowes (Midwest) 60 amp GFCI for my Hamilton. Of course I had a certified electrician (Friend) come over and triple-check everything before firing up. No problems whatsoerver.
lumin4
« Reply #6 on: October 14, 2013, 01:48:32 pm »
Yes, evidently the Gfci breakers become faulty within 2 years; big problems!
