Original
Protecting hot tub from construction debris?
Pages: [
Topic: Protecting hot tub from construction debris? (Read 2406 times)
kervis
Full Member
runnergirl
on:
May 15, 2008, 11:07:32 am »
We will be adding on to our house--going up and adding another level. We will need a whole new roof.
I just got a new skin for my hot tob cover. (see other post!) I would like to protect it from flying shingles.
Do I just get a giant sheet of plywood and cover it? I assume I would want to take it off at night so it doesn't squish the foam flat.
I think I should put down a bedsheet first so that the plywood doesn't scratch the cover.
Does that sound fine or should I do something different?
Thanks.
2005 HS Vanguard
on:
Mentor Level Member
Re: Protecting hot tub from construction debris?
Reply #1 on:
May 15, 2008, 11:42:03 am »
The sheet of plywood sounds like a very good idea. Don't know if the sheet is needed, but it sure can't hurt. I reside my house last year and was worreid about my hot tub (and pool) I didn't think to put the plywood over the cover, thankfully nothing happened.
Mentor Level Member
Reply #2 on:
May 15, 2008, 12:55:17 pm »
I'd probably lay a tarp over the entire spa and then put plywood over the cover. The weight of the plywood should not effect the cover since its equally distributed and not heavy per in˛.
Ultimate Member
Retired (mostly) from the industry after 33 years
Reply #3 on:
May 15, 2008, 01:21:53 pm »
Home Depot, 2 sheets of 1/2" OSb (about $8 a sheet. Throw them on top of the spa the spa, cover with a tarp.... then send your roofers my way, I need a new roof too. :-/
SDCPL858
Junior Member
Reply #4 on:
May 15, 2008, 03:47:26 pm »
OSB/plywood sounds like the best idea to me.
Ultimate Member
Reply #5 on:
May 15, 2008, 06:11:03 pm »
OSB/plywood
$8/$30
OSB all the way.
Reply #5 on:
Pages: [
Original
