Author Topic: Fresh Water III ozone  (Read 3311 times)
Big1Dog
« on: May 03, 2008, 11:01:41 pm »
My Vanguard ozone system just started to make a lot of bubbles,  anyone got a guess? The spa is only a year old.
The_real_Clown_Shoes
Re: Fresh Water III ozone
« Reply #1 on: May 05, 2008, 01:03:58 pm »
Could be a problem with the check valve.  Is it putting off a larger odor than usual?
« Reply #2 on: May 05, 2008, 06:58:12 pm »
Isn't it supposed to be making a lot of bubbles? :-/
« Reply #3 on: May 05, 2008, 07:04:34 pm »
Had you just drained and refilled by chance? I've seen the size/qty of bubbles vary after a drain/refill.
Big1Dog
« Reply #4 on: May 06, 2008, 12:44:11 pm »
There is quite a volume and the bubbles are large.  Started before I changed the water.
shabba
« Reply #5 on: May 06, 2008, 01:01:17 pm »
Did you by chance have the wellspring waterfall feature on the whole time you've had the spa... If so, that can be the cause of the increase in number and size of the bubbles, considering the water feature takes flow away from the circ pump when in use.  Just a guess.
