Author Topic: Closing the Hot Tub  (Read 2912 times)
hottbpete
  • Caldera Niagara
Closing the Hot Tub
« on: April 21, 2008, 02:26:25 pm »
I am going to be away for 5-6 weeks.  The Hotub will not be used during this time.  Any suggestions on if I should dump the water and leave it empty for the month and half.  It will be in late sprintg early summer.
If I do empty it.  Should I leave the cover off?  Blow out the pipes?
Thanks in advance for the advice :)
Closing the Hot Tub
BauerN
  • "...to feel is to believe."
Re: Closing the Hot Tub
« Reply #1 on: April 21, 2008, 02:58:31 pm »
For the easiest solution (besides a tub-sitter), I would advise draining.  It'll be a lot nicer to fill with fresh water, than to potentially troubleshoot a gunky spa.
Blowing pipes out would probably be helpful (I don't know if it'll be worth the effort).
I recommend leaving the cover in place to keep debris, etc out of your spa.
I am NOT one of the true chem experts here, one of them may have better advice.
webboy
  • hey bub
« Reply #2 on: April 21, 2008, 03:22:15 pm »
I agree with BauerN,
Definetly put the cover back on! You would run into all kinds of problems leaving your spa shell in direct sunlight all day.
I would treat this like winterizing your spa, without the antifreeze. Here a step by step procedure
http://www.bullfrogspas.com/pages/customer-maintenance.asp#m17
Good luck
