I had nice stable water chemistry for months, then came time to drain and refill.It doesn't look bad:Calcium= 280pH= 7.8TA = 61But I would prefer the pH to be a tad lower and the TA to be a tad higher.What should I do?
Muriatic acid should IN NO WAY be used to adjust pH even if diluted. This product is ONLY used for EXTREME cases of high TA (500ppm+) and should not be used in a spa otherwise!! It is designed to knock out high TA and not for minor adjustments of pH.
Not to mention how much harder it is to handle and store muriatic acid (liquid) compared to dry acid (powder)... 8-)
Soak King is correct.Raise TA.Then drop pH.
