Author Topic: LOST 300 gallions of water Jacuzzi J-355????  (Read 17983 times)
loosenupspas
Re: LOST 300 gallions of water Jacuzzi J-355????
« Reply #15 on: February 13, 2008, 04:50:28 pm »
pipe snapped, shell cracked, some leak with a large diameter.......300 gals in two hours is large, very large......good luck
Chad
  • 2006 Jacuzzi J-345
« Reply #16 on: February 13, 2008, 05:58:15 pm »
Make sure your drain cap is secure.
« Reply #17 on: February 13, 2008, 06:48:20 pm »
It is ok to post nude pictures on this forum now?
This is the same nitwit Clownshoes (Not the legit user we have with a similar name. )I banned his IP, and he got another. I've banned the addresses he registers with. None of these will keep out a determined person.  I'm working with his ISP. His ISP is a big multistate one (not in Colorado) For now, I have blocked out a range of ISPs that should keep him out for a while.   The first time he registered he used a yahoo email account that anyone can create, but this time he made the mistake of registering with a email account that had to be created at his own ISP.   His name, or someone who loaned him theirs appears to have a last name of Flynn.
« Last Edit: February 13, 2008, 06:59:11 pm by wmccall »
« Reply #18 on: February 13, 2008, 07:31:58 pm »
Nice going there boss, and kudos to Bonibelle!
johnnythunders
  • Jacuzzi J-355
« Reply #19 on: February 13, 2008, 08:16:49 pm »
Geeee I am going to have to get the repair done by the company that sold me the jacuzzi.Might as well let them look for the leak or crack......I hope its a crack so they have to replace it lol...
Yea but would you think 300 gallions would show up somewhere?
No leaks on my slab or no melted snow.....It makes me wonder...Thanks allll...JT
« Reply #20 on: February 13, 2008, 08:35:09 pm »
 If its only 4 years old its still under warranty, let the dealer handle it!
« Reply #21 on: February 13, 2008, 09:20:36 pm »
Agreed, its great having her around, she can be on more during the daytime than I can.
« Last Edit: February 13, 2008, 09:21:13 pm by wmccall »
johnnythunders
  • Jacuzzi J-355
« Reply #22 on: February 15, 2008, 03:47:51 pm »
Geeeeee the guy came by today while I was not at home to fix the spa..
I came home and on the invoice it said that my spa was about half full
and he could not find a leak at all.....
So I was charged the $100 service call and another one for $60 for labor.......
I don't mind paying the $100 but what was I surposed to do when I see half or more of the water gone????I am calling the owner tomorrow about the labor........
But the spa is not leaking now any w wondering why or how can I lose about 300 gallions with 2 hours and not see any leakage around the spa?????Hummmm JT
« Reply #23 on: February 15, 2008, 04:07:12 pm »
 Well for one, the service tech or you should have filled it?   If you did have it filled and the water ran out, the service guy should have done something other than leave you a bill??  ::)  Or your faucets are all wrapped up and or the hose is frozen?
 A quick way to see if its leaking water is to open the right or left side of the panel just enough to get your hand to a corner,  stick your hand down in the corner and touch the btm of the abs pan if there is a couple inches of water there its leaking.   I would call the dealer and talk to them either way!!
 Sounds like a lazy tech!!!!
« Last Edit: February 15, 2008, 04:08:14 pm by Jacuzzi_Jim »
johnnythunders
  • Jacuzzi J-355
« Reply #24 on: February 15, 2008, 04:53:30 pm »
Yep you are right...
Jacuzzi told me to leave it as it is and put a space heater under it....
But the tech filled my spa up with water and I guess there was no leaks as the invoice says.
I have been useing Chemicals for the last hour and still no leaks....
Yes I could have took the side panel off,,,,but if I lost 300 gallions of water I think it would have been leaking out on all sides of the spa....
Whaty annoys me is a labor charge of $60 above the $100 service call....I will call the owner tomorrow...I am sure he will wave that charge,well I hope he does lol.....JT
Chad
« Reply #25 on: February 15, 2008, 05:23:58 pm »
johnnythunders
  • Jacuzzi J-355
« Reply #26 on: February 15, 2008, 08:26:30 pm »
 drain cap is secure.......
I have been useing it without any problems for 4 years....
If  drain cap was not secure I would see melting snow off of my slab......
I just don't get it,,,,,,the freaking spa is working great now and not losing any water at all.......
Nothing has changed,tech came over and saw there was no leak.....
But I still feel I did the right thing,,,,If it looks like a big leak  ,shutttttt off the spa...
Maybe I am wrong lol.....Thanks JT
Richs100
« Reply #27 on: February 15, 2008, 08:34:05 pm »
Johnny, are you sure your not the butt of a practical joke? Like removing water at night?
Can't think of anything else....
johnnythunders
  • Jacuzzi J-355
« Reply #28 on: February 15, 2008, 09:48:47 pm »
Geeeee I would say you might have been right....
The family that lives next to me is a acre away lol
And as I said the water was lost between 4pm and 6pm,enough daylight lol.
Just hope this does not happen again,I am afraid if it happened once,that it might happen again.....Thanks for yea good advise............JT
« Reply #29 on: February 15, 2008, 11:53:02 pm »
Man, they must really have a issue with you to do that in daylight when they're not even that close!!!
