Author Topic: How often does your spa go over 104 degrees?  (Read 12557 times)
solo
« on: December 10, 2007, 03:49:12 pm »
I have found that I really like the 104 degree setting.  It's now my fave temp.  Leaving my tub set at 104, I find that often it's down at 103 and occassionally it gets up to 106.
I have a separate "floater" thermometer that I leave in the spa to make sure the temp readout is correct.  And it always is.
Is this sort of fluctuation fairly typcial?
Re: How often does your spa go over 104 degrees?
« Reply #1 on: December 10, 2007, 04:04:56 pm »
 Spas will and can vary 1* up or down, least in Jacuzzi's anyway.
Chad
  • 2006 Jacuzzi J-345
« Reply #2 on: December 10, 2007, 04:19:04 pm »
That is exactly what mine does if set at 104.
I keep mine set at 103 during the winter and it is almost always atleast that high. If it's at 102, I set it to 104 and wait until I hear the heater click on(about 10 seconds) then I set it right back down to 103 and go inside for about 5-10 minutes.
dax
  • '07 Sundance Cameo
« Reply #3 on: December 10, 2007, 04:21:23 pm »
Temps here in eastern Pennsylvania have been in the 20's of late.  Thought for sure that I would be cranking up the heat on the hot tub during this time.  But I really think 100/101 is hot enough for me.  Maybe I'll crank it up some night just to check it out, but I find myself sitting in the cool down seat a lot as it is during each soak.  And yes, I have a floater themometer, and it matches what the spa display reads.
TheSpaExpert
« Reply #4 on: December 10, 2007, 04:23:43 pm »
You should never let the water get above 104.
Please be more careful and take precautions to prevent this from occurring.
Enjoy your spa.
Bonibelle
  • '05 Marquis Epic
« Reply #5 on: December 10, 2007, 04:27:10 pm »
It is so interesting how some people are more tolerant of higher temperatures. My husband loves the tub at 102 and I cook! At 101, I am fine, but that one degree is just too hot for me. We even fight over that....he will hit the spa monitor and kick it up a degree  ::)and think I won't even look at the temp when I get in!!  >:(
My tub holds the temp very well unless the air is turned on and it is real cold outside, it may drop a degree while we soak. It rarely goes over the set temp.
Solo, have you noticed an improvement in your health? I hope the tub has helped because you sure seem to be enjoying it!
TheSpaExpert
« Reply #6 on: December 10, 2007, 04:32:23 pm »
Violence is never the right solution.  Although he is directing his anger towards the hot tub, it is simply not worth chancing a hostile encounter.
Marquis Spas are owned by the employees.  This instills a since of pride in their products.  I am sure that the owners/employess would not like hearing that their spas are being subjected to this type treatment.
Keep it below 104.
« Reply #7 on: December 10, 2007, 04:39:43 pm »
I never see 106, but according to Dynasty if my tub is at 104, the heater doesn't come on until the tub reaches 103, then runs till it hits 105.  I have to catch it right as it shuts off to see 105
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #8 on: December 10, 2007, 04:52:00 pm »
Unless you want it hotter  ;)
orbitaljoe
  • 2007 J480...        It's a Jiquewzy, Hon
« Reply #9 on: December 10, 2007, 05:08:22 pm »
It's also really strange how you can so easily notice a one or two degree temperature rise (or fall)...
101-102 is just right for me...
Bump it up to 103-104 and I'm looking around for potatoes, carrots and onions floating in there with me... :o
Just a newbie observance
Lovin' Jacuzzi  8-)
« Last Edit: December 10, 2007, 06:04:21 pm by orbitaljoe »
Ain't the beer cold!
LtDan
  • Jacuzzi J345
« Reply #10 on: December 10, 2007, 05:35:32 pm »
I thought I read that the heater (in Jacuzzi) doesn't kick on or off until you have a 2 degree deviation from the set temp. Mine certianly follows that.
And I routinely have occasions where violence is the perfect, often only solution. Never in the hot tub though!  ;)
TheSpaExpert
« Reply #11 on: December 10, 2007, 05:45:04 pm »
Violence only begets more violence.  It is never ending as someone is sure to escalate it.
Talk to one aother.  Try to find common ground.  The hot tub is a great place to reconnect, not intersect.
Bonibelle
  • '05 Marquis Epic
« Reply #12 on: December 10, 2007, 07:03:04 pm »
Ooooh I hear what you're saying...No violence. ::) I just bring him a nice glass of wine, put some nice music on the soundsations :) (like Andrea Bocelli)..He relaxes in HIS >:( Adirondack Chair, sips his wine and I slip over to the control panel and TURN THE TEMP BACK DOWN TO 101.. :o :D No violence...but since I maintain the tub, dump, clean and refill the tub and buy all the chemicals...I CONTROL THE TEMERATURE  >:( ;D ;D ANY QUESTIONS???
Repeat_Offender
« Reply #13 on: December 10, 2007, 07:17:06 pm »
No ma'am......I'm a big believer in 101 myself.
« Last Edit: December 10, 2007, 07:25:52 pm by Repeat_Offender »
Bullfrog 562
Chad
« Reply #14 on: December 10, 2007, 08:13:17 pm »
That is correct, it doesn't kick on until a two degree temperature drop from set temp. However, It will typically kick off once it reaches one degree higher.
« Last Edit: December 10, 2007, 08:16:29 pm by WHY_NOT »
