Author Topic: Which Taylor test kit  (Read 2702 times)
IlliniFan
« on: December 02, 2007, 11:19:50 pm »
Which Taylor test kit do you all recommend?  I am using bromine.  Thanks!
sonofsail
  • Hi Y'all
Re: Which Taylor test kit
« Reply #1 on: December 02, 2007, 11:45:25 pm »
I use K-2005.  It looks complicated but instructions are right on inside of cover and easy to follow.  It has every test you should need.
http://www.taylortechnologies.com/products_kitinfo.asp?KitID=2227
Happy to help a Big Ten Fan.....Go Badgers. :)
"Growing older but not up..."
IlliniFan
« Reply #2 on: December 03, 2007, 12:06:23 am »
solo
« Reply #3 on: December 03, 2007, 12:53:11 pm »
Would I really have any need for anything more than the DPD Delux test kit?  This seems to cover the basics.  And if I'm having problems I simplyh take a sample to the dealer I buy chemicals from.  He tests everything and tells me what to add.
http://www.lesliespool.com/shopping/product/detailmain.jsp?itemID=8200&itemType=PRODUCT&iMainCat=15&iSubCat=128&iProductID=8200
« Reply #4 on: December 03, 2007, 08:00:41 pm »
The bromine kit has a different number - they list a K-2105 and it has bromine as it's DPD test ... it may just be the same.
They also make a DPD FAS kit that is even more accurate than the regular DPD kit for testing chlorine/bromine. I almost bought one but never did. It apparently can measure any amount of chlorine to either 0.2 PPM or 0.5 PPM accuracy.
The geek in me really wants to buy one!
