Author Topic: F settings for jacuzzi in cold weather  (Read 2857 times)
IlliniFan
« on: November 04, 2007, 09:33:14 pm »
What  F settings do you use in cold weather?  Do you vary them depending on temperature outside?   Thanks for your help.
Chad
  • 2006 Jacuzzi J-345
Re: F settings for jacuzzi in cold weather
« Reply #1 on: November 05, 2007, 06:09:53 am »
Good question.
Last winter was my first with a spa. I kept it set for F3 because I have the mindset that more is better. Then this past spring I experimented with less programmed cycles and there was no change to my water quality. I guess our 24 hr circ pumps do a pretty good job by themselves. So I have been keeping it on F1 ever since. I even noticed a decrease on my electric bill. I think the key is to set it for the lowest amount possibly w/o effecting your water quality.
I might set it back up to F2 or F3 if I start noticing that when I go out to soak, my water is constantly below my set temp.
« Last Edit: November 05, 2007, 06:14:13 am by WHY_NOT »
spa-ing
« Reply #2 on: November 05, 2007, 12:17:32 pm »
Whatever keeps it at 101 degrees.  I'm in the Chicago area as well.  We never use it when it is windy however.
