Author Topic: crack in spa  (Read 3993 times)
grouseblue
crack in spa
« on: October 26, 2007, 04:36:40 pm »
Hi can eny one tell me i have just found a small crack about one inch long just above the filter tray it above the water line his this easy to fix thanks for eny help
crack in spa
Re: crack in spa
« Reply #1 on: October 26, 2007, 05:13:07 pm »
I think if we knew what brand/model of spa you have it might be helpful- shells may be made of different types of materials, and some may be easier to fix than others.
grouseblue
Re: crack in spa
« Reply #2 on: October 26, 2007, 05:20:15 pm »
Hi its a infinity spas and its the paicifica thanks for you help
spaman--
Re: crack in spa
« Reply #3 on: October 26, 2007, 05:35:55 pm »
Oh an infinity  :( I am afraid I have bad news :'( The only way to fix it is to trade it in towards purchase of a D1 from SpaMan.
Ok now to reality, You may be able to purchase a repair kit from Dr.Spa as that is what I would do if I were a consumer and had that problem. ;D
-SpaMan~
grouseblue
Re: crack in spa
« Reply #4 on: October 26, 2007, 05:39:40 pm »
thank you for you help i will do as you say thanks again
loosenupspas
Re: crack in spa
« Reply #5 on: October 26, 2007, 05:40:48 pm »
Water exerts much pressure on your shell.  It may just continue to crack, slowly.   It is hard to fix a crack....is there a warranty?  Find a marine supply company and see what they might suggest.  Is the ground under the spa level?  Something caused a crack, determine what caused it and fix that problem first.  Good Luck and be careful out there in the hot tub!!!!!
Re: crack in spa
« Reply #6 on: October 26, 2007, 05:51:56 pm »
 If its not under warranty you can drill a very very small pilot hole at each end of the crack then epoxy with a good type epoxy.   Should work and should not spread??
Richs100
Re: crack in spa
« Reply #7 on: October 26, 2007, 06:26:22 pm »
Jim...
Should the pilot holes look like periods?
or commas?
or any other kind of punctuation?    ;)
grouseblue
Re: crack in spa
« Reply #8 on: October 26, 2007, 07:28:41 pm »
thanks to ever one for there help and advice
leaky
  • Don't ask about the nickname...
Re: crack in spa
« Reply #9 on: October 31, 2007, 02:41:31 pm »
A bit off topic...
Not sure, but I'm guessing that "grouse" is of the younger, AIM/blog/text generation?
That would explain why there appears to be no need whatsoever for any form of punctuation..... ;)
grouseblue
Re: crack in spa
« Reply #10 on: October 31, 2007, 03:18:33 pm »
For your information I was born in 1946 in London UK so I doubt that I am from the younger generation. I had to leave school at 15 to earn a living unlike the more fortunate that had well off parents to pay for college education. If the lack of punctuation upsets you then "tough" :P
thearm
  • EMERALD CLASSIC all the way!!!
Re: crack in spa
« Reply #11 on: October 31, 2007, 08:06:43 pm »
grouseblue,
Very well done. I''ll bet Leaky even feels bad! :-[
Richs100
Re: crack in spa
« Reply #12 on: October 31, 2007, 08:45:19 pm »
Some believe punctuation is also a courtesy to the reader from whom you are seeking information.
It makes it easier to read your inquiry, understand your issue, possibly respond with helpful information, and avoid getting a headache.
Good luck with your crack.
Re: crack in spa
