Author Topic: Taylor Kit users or Math majors help.  (Read 2675 times)
96SC
« on: October 20, 2007, 10:47:04 am »
Using the Taylor booklet, table A, to introduce 1 ppm chlorine.  If I have a 400 gallon spa and want to add 1ppm with 56% chlorine, how much would I use?  The booklet gives results for 45% and 60 % chlorine.  To the best of my 'sypherin' I come up with .1 oz.  Does that sound right?  (Math majors, here are the amounts given:  45%= .12 oz and 60%=.09).
The container label is no help either.
Thanks. :-/
autoplay
Re: Taylor Kit users or Math majors help.
« Reply #1 on: October 20, 2007, 10:54:15 am »
Don't over-think it lol.  I add bout 1.5-2 ounces of di-chlor,AFTER I'm done using spa.  That typically lasts in regards to sanitation....3-4 days.
« Reply #2 on: October 20, 2007, 11:05:44 am »
Since you are using 2 items you must add them together  and divide by 2 to get the average.
(45+60)/2 = 105/2 = 52.5 SO (.12 + .09)/2 = .105 ... so the answer is NO it is not 1 oz! 1 oz is going to give you 1 PPM if the chlorine was 52.5 %   Try again!!!    ;D ;D Now to add to your misery, each teaspoon is 0.16 oz so you need to know how much chlorine does a teaspoon give you.  8-)
**Just kidding**  ... I did the calculations a while ago and you need 0.096 oz of 56% dichlor to give you 1 PPM chlorine.
To make it even easier for you, I have a 400 gallon tub and I use 2 heaping teaspoons to get about 3 PPM +/- something. The only difference I use chlorine from Doc that has 62% active ingredients and the amount needed to get 1 PPM is 0.087 oz.
96SC
« Reply #3 on: October 20, 2007, 11:42:40 am »
.1 oz. vs. .096 oz.  Close enough for government work. [smiley=thumbsup.gif]
Thanks for the input guys.
Chad
  • 2006 Jacuzzi J-345
« Reply #4 on: October 20, 2007, 04:09:14 pm »
Thanks. :-/
gallons of water in tub x desired ppm x .000128 / % of available chlorine in dichlor = amount of dichlor to add in ounces.
Example -  400 x 1 x .000128 / 56%(.56) = .091 ounces
3 tsp per TBS
2 TBS per Ounce
