Author Topic: Water Change Question  (Read 2696 times)
Brookenstein
« on: October 06, 2007, 11:23:36 pm »
If I refill the tub and start with dichlor say on Sunday and say a few days later get my new bromine stuff, do I just throw in the bromine in the floater?  Do I skip the the activator stuff that I would normally use?  Would it be better to just keep the tub empty until I get the new chemicals or is it okay to get started with the dichlor?
Re: Water Change Question
« Reply #1 on: October 06, 2007, 11:52:07 pm »
Go ahead and start with your dichlor.
You should still use the activator when you switch.
« Reply #2 on: October 07, 2007, 08:55:43 am »
You can at any time change a chlorine tub to a bromine tub.  The only way to change a bromine tub to a chlorine tub is to drain and fill with new water.  As soon as you put bromine into a chlorine tub, it becomes a bromine tub for the duration of that water.
