Author Topic: Remove Insulation Foam  (Read 22457 times)
86ward
« on: August 06, 2007, 05:30:24 pm »
Hello,
I moved my tub and I have several leaks in my hot tub, the model is a Catalina.  However I can not access the plumbing
Due to the insulation foam they have sprayed it with.  How do I remove this foam, I have tried several chemicals but nothing seems to work
besides pouring gasoline and setting it on fire, does anyone know how I can remove this foam to acess the plumbing?  Thank you
Cola
  • Time for bed kids
Re: Remove Insulation Foam
« Reply #1 on: August 06, 2007, 06:16:43 pm »
A knife - be carefull
Your fingers
The_real_Clown_Shoes
« Reply #2 on: August 06, 2007, 06:16:58 pm »
Good old fashioned chisel and dig.
104 degrees
« Reply #3 on: August 06, 2007, 07:18:18 pm »
date=1186438603]A knife - be carefull
Your fingers
Steve[/quote]
The pipes too :)
86ward
« Reply #4 on: August 06, 2007, 08:41:07 pm »
Please tell me there is another way? I have knifed and chissled to the bone, but thanks for the advise.
« Reply #5 on: August 06, 2007, 10:02:37 pm »
I always like a small claw hammer.
hotubinn
« Reply #6 on: August 07, 2007, 01:31:09 am »
Screwdriver works also!
rick
« Reply #7 on: August 07, 2007, 11:40:22 am »
You poor bastard.
FF spas.   More efficient?  Not.   Less prone to leaks?   Not.    Pain in the ass to find a leak?    Bingo!
(poking in my Coleman,  wow!  the plumbing's right in front of my face)   what a novel concept.
Pretty sad when the FF advocates here offer nothing but sarcasm for advice.    And you forgot one:
"try a divining rod,  just point it at the foam and it will steer you to the leak"         :D
How many times have I heard them all say,  "finding a leak in a FF spa is not that hard"
Appearantly it is.
« Reply #8 on: August 07, 2007, 12:15:43 pm »
You poor bastard.
Appearantly it is.
 If you know what your doing its not that difficult,for the average home owner thats never done it, its a learning experience.
East_TX_Spa
    • I Love My Spa
« Reply #9 on: August 07, 2007, 12:28:04 pm »
http://www.catalinaspas.com/ourtechnology.htm
Thermal Pain must not be dat easy either.
Terminator
Richs100
« Reply #10 on: August 07, 2007, 12:49:58 pm »
You poor bastard.
Appearantly it is.
Hey Rick
As Term just pointed out by his link, CATALINA IS A THERMAL PANE SPA!
I think 86ward is having trouble with the insulating foam they have sprayed on the bottom the tub and the plumbing.
I wonder what the cause of his leaks were?  Could it be vibration? Lack of Support? Insufficient insulation?  I wonder.......
Maybe if it was a full foam spa, it wouldn't have these leaks to begin with?  I wonder.....
Rich
rick
« Reply #11 on: August 07, 2007, 01:44:48 pm »
Doh!    :o
Hang on guys,  it takes a while to pull one's foot out of one's mouth!
PS:  Catalina is not the TP that my grandfather drove.  Looks more like a Prius,    a hybrid.
I thought the whole point of TP was while maintaining energy efficiency,  to be able to access the innards painlessly.
Terminator
hot tub Frank
  • tiger river bengal
« Reply #12 on: August 07, 2007, 07:29:42 pm »
i would hate to have those problems
Pathfinder
« Reply #13 on: August 07, 2007, 08:05:41 pm »
Rick, there are many takes on the T P design  being able to access the plumbing is more of a marketing than design approach.  Now digging through 2& 5lb closed cell is a huge pain in the ass.   When dealing with tubs like that I use a drywall saw that has interchangeable blades. The blades are sharp enough to cut out chunks but dull enough to not go through the piping.
104 degrees
« Reply #14 on: September 19, 2007, 04:06:25 pm »
You poor bastard.
Appearantly it is.
Cheap spa sales must be hurting ;D Back to the corner for you ;D
