Author Topic: Water problem  (Read 3555 times)
galen
  • Maxxus
Water problem
« on: September 14, 2007, 07:42:14 pm »
I have white stuff floating in the water. I don't know what it is but I'm asuming its coming from inside the pipes of the tub. Does anyone know what I should do?
Change the water? Thanks.
Water problem
Re: Water problem
« Reply #1 on: September 14, 2007, 08:04:51 pm »
It sounds like white water mold.   :(
See http://www.rhtubs.com/decontamination.htm for solution. :'(
In Canada eh
Re: Water problem
« Reply #2 on: September 14, 2007, 08:46:54 pm »
Galen,
   The only thing Doc's information skipped was to make sure you dechlorinate the water before draining you tub.  Sodium thiosulfate is the most widely used after super chlorination of a watermain before flushing.  You really don't want to send 50ppm of chlorine out over your lawn or down the street to the sewer.
Bullfrog 451
Re: Water problem
« Reply #3 on: September 14, 2007, 09:26:14 pm »
What kind of white stuff?  Slimey?  Stringy?  Suddsy?
galen
  • Maxxus
Re: Water problem
« Reply #4 on: September 14, 2007, 11:00:43 pm »
Well I say its white, its kind of light in color, off white, like a flake. Slimy. It mostly floats along the side. I take a pool net and skim it off. Its not real bad, but enough that I skim it off. I've super chlorinated it twice. I read that article you posted and that was enough for me. I've started the decontamination process. Thank you!
« Last Edit: September 14, 2007, 11:37:10 pm by galen »
Re: Water problem
« Reply #5 on: September 15, 2007, 09:09:19 am »
If its organic, you must decontaminate.  If its hard and scaley, it may be mineral.  Slimy sounds organic to me.
Richs100
Re: Water problem
« Reply #6 on: September 15, 2007, 10:38:07 am »
Here's where Spock's Tricorder would sure come in handy!
Re: Water problem
« Reply #7 on: September 15, 2007, 10:40:59 am »
"It's organic, Jim!"  Dr. McCoy ;)
D.P. Roberts
Re: Water problem
« Reply #8 on: September 15, 2007, 07:50:56 pm »
"I'm a doctor, not a hot tub repairman!"
Richs100
Re: Water problem
« Reply #9 on: September 16, 2007, 08:30:01 am »
"But how does it go with Scotch?.....I'll let ya know!"  Scotty  :)
galen
  • Maxxus
Re: Water problem
« Reply #10 on: September 16, 2007, 04:30:49 pm »
OK I identified the white flake. Its a build up of calcium inside the pipes. Every time I would turn on the pumps I get a new dose of flakes. I took a collection of flakes in a glass of water. Added clorox to it and waited one hour. The flakes were still there. I took another collection of flakes without water and added Mauriac acid to a plastic spoon. In one hour the flakes were gone. I need to lower my Ph for awhile, to rid the buildup.
Re: Water problem
« Reply #11 on: September 17, 2007, 08:29:45 am »
Its not organic.  Good job on the diagnosis.
Re: Water problem
« Reply #12 on: September 17, 2007, 12:29:55 pm »
Awesome diagnosis! :)
Re: Water problem
