Author Topic: Refill questions on Marquis spa (bromine)  (Read 3745 times)
cajun1
« on: August 26, 2007, 10:02:13 am »
Okay, we're doing a dump/refill and I want to get the order right on putting in the chemicals because after my first dump, it took FOREVER to get the levels right.  I have a Marquis Epic with the in-line bromine system.  I have a soidum bromide package to add (to establish a bromine reserve?), but I'm not sure at which point I do that.  And when do I shock?  If someone could walk me through the steps on when to add which chemicals on refill, I'd appreciate it.
stuart
Re: Refill questions on Marquis spa (bromine)
« Reply #1 on: August 26, 2007, 12:59:29 pm »
Cajun,
make sure that you take your bromine cartridge out until the spa is heated up or you will dump more bromine into the tub then you want to.
Wait for the spa to heat to at least 90 degrees and then add about 1-2 oz of bromine concentrate.
The first thing I would do however, is to make sure you ALK and PH are correct.
BTW, just out of habit I always leave my cover open for a bit after I add chlorine or bromine.
I wouldn't shock it until after use....
So here are the steps
1. at fill pull bromine cartridge for 24 hours
2. at 90 degrees test levels and add 1-2 oz of bromine
3. after spa is at temp set cartridge to 1 or 2 and install
4. shock about an oz after each use
« Last Edit: August 26, 2007, 01:01:54 pm by stuart »
« Reply #2 on: August 26, 2007, 08:51:02 pm »
Cajun,
Is this the frog system you are describing?
cajun1
« Reply #3 on: August 26, 2007, 09:55:00 pm »
hot tub dan, were you asking me or stuart?  If it's me, yes, it's the spa frog in-line bromine/mineral system.
« Reply #4 on: August 27, 2007, 10:02:31 am »
Thanks.  The question was for either of you.
Relax and enjoy! :)
