Author Topic: Where can I find a wiring diagram for a Dynasty?  (Read 3434 times)
Nitrousman
« on: July 20, 2007, 12:29:41 am »
I need a wiring diagram for 2003 Dynasty Excalibur tub so I can try and figure out if the pumps bad. Thanks.
Pathfinder
Re: Where can I find a wiring diagram for a Dynast
« Reply #1 on: July 20, 2007, 12:48:33 am »
If the previous owners chems were bad check to see if there are deposits built up where the seal is. It just might be the seal going.  If its like most spas the wiring schematic should be on the inside of the front panel of the spa pack. The pump wiring should be on the pump.
Nitrousman
« Reply #2 on: July 20, 2007, 11:26:42 am »
OK, I'll check that tonight. I know the jets have some calcium buildup on them from the well water. THanks.
