Author Topic: Is a Strong Spa Antigua any good - anyone got one?  (Read 6737 times)
Madeinireland
« on: June 20, 2007, 05:32:03 pm »
Hi,
Does anyone out there have the model mentioned in the subject line. I'd really like to know how good these rotationally moulded spas are? Are they just cheap and will fall apart in a year or so - or will they last 5 or 6 years.
Help appreciated.
Thanks...
Mark
East_TX_Spa
    • I Love My Spa
Re: Is a Strong Spa Antigua any good - anyone got
« Reply #1 on: June 20, 2007, 05:40:28 pm »
It looks to be a fairly well-made $2-3,000 spa.  I wouldn't spend a dime more than that for it, but if you just want a tub to sit in that has warm water and bubbles, it would probably be worth the money.
Don't know about the quality of the pump or components, but the tub itself should be pretty durable.
Good luck! :)
Terminator
Gary
« Reply #2 on: June 20, 2007, 06:26:27 pm »
The real question is "what if needs service", even if it only cost $1,000 if you have trouble getting it fixed you still wasted a lot of money.
hotubinn
« Reply #3 on: June 21, 2007, 11:48:19 am »
I have seen a number of leaks from these types of tubs.  Normally they leak from between the jet and the shell.  The spa itself is a complete mold with holes in bottom the assemble plumbing.  Once they have plumbed the tub, they fill holes with foam= no repairs possible on a leak.  I have seen brand new tubs that leak, then go to the junk pile!
Madeinireland
« Reply #4 on: June 21, 2007, 12:05:59 pm »
Thanks for the info - Was your experience related directly to the strong spa make ?
Also on being foam filled - I can't quite understand why you can't just perhaps put some dye in the water to determine the point of leak - rip out the foam and replace when finished - or am I being too simple?
Regards...
Mark
Gary
« Reply #5 on: June 21, 2007, 12:10:42 pm »
Regards...
Mark
Anything can be fixed but you have to weigh in the cost of fixing it and see of it makes sense to do it.
