Author Topic: Hot Weather  (Read 2631 times)
galen
  • Maxxus
Hot Weather
« on: June 17, 2007, 11:26:44 pm »
Do any of you cut back on soaking during hot weather? I just can't seem to get in the mood to soak if its hot out. Do you lower the temp. to make it feel refreshing?
« Last Edit: June 17, 2007, 11:27:38 pm by galen »
Hot Weather
autoplay
Re: Hot Weather
« Reply #1 on: June 17, 2007, 11:39:19 pm »
In FL,where I live,it's impossible to lower the temp,with cover on,and without ice-cubes,in the summertime.
I looked today,the spa temp was 103 with cover on,heater set at 84.  Heater never runs in summertime.
To answer your question,I seldom use the spa in summertime. I use the pool,which today was at 89 degrees.
D.P. Roberts
Re: Hot Weather
« Reply #2 on: June 17, 2007, 11:47:07 pm »
I often feel like I don't want to go in, but once I actually start soaking I find that I can definitely enjoy it when it's warm out. As long as the outside temp is less than 90 or so, and the tub temp is in the upper 90s, I'm fine.
Re: Hot Weather
