Original => Hot Tub Forum => Topic started by: kayaknva on January 24, 2007, 09:17:31 pm
Color blind, need to know if there is an digital test out there that doesnt cost an arm and a leg. Has anyone used one that is correct?
Thanks in advance!
Doc mentioned a new digital test strip reader that he was considering selling a few months ago and wanted someone to test. I believe Vinny volunteered. Check rhtubs.com to see if he is carrying it.
Not yet available. I have it on back order, from I think, 4 different suppliers ;D
If you want another "beta tester" when you finally receive them, I'd love to see how they work. :)
I use a LaMotte digital tester and it works great. It's a lot more accurate than the test strips. It's not that cheap, but I now feel a lot more confident in my water testing with these old eyes. Here is a link
http://www.askalanaquestion.com/electronic_testing_meters_store.htm
There are a lot of meters on that page. Which one do you use? Thanks
I use the PC-4A. I have a bromine system. The meter measures clorine, Alk & PH. To get a true bromine reading, you get the total clorine reading and times that by 2.25. Has worked great for the last 6 months. I still have test strips left that I also use on occasion, but to be accurate I use the meter.
Sugarbear,
To post a clickable link, click on this icon (http://i144.photobucket.com/albums/r165/tileman_photos/url.gif)
in the Add YaBBC tags: Then insert the link in between the http:// :D
Thanks Bear, that price isnt that bad at all. I was looking online and saw all the $600 plus systems. How do you measure your TDS? I see that other meter at the bottom and wondered if you have that one as well.
Thanks again!!
Not Yet! I'm a gaget FREAK! If there is a gaget out there to do a job...I probably have it. Have not had to worry about TDS as of yet. The tub is at our weekend home, so it only gets limited use at the moment, but I have looked into it. Good Luck!
