Original => Hot Tub Forum => Topic started by: MostlyLurkingGal on January 03, 2007, 10:44:19 pm
Title: Help please....Jetsetter acting funny!
Post by: MostlyLurkingGal on January 03, 2007, 10:44:19 pm
Figures with my luck, this forum would be down the night I have a problem!
Anyway...here's the scoop:
There is a slight gurgling noise that I never heard before, and bubbles are coming up from the floor where the hot water enters. Term told me awhile back that I don't have an ozonator in a '95 Jetsetter....so it's not that (unless one was installed aftermarket and wasn't working until today) but I imagine if it did have an ozonator, this is what it would look like....bubbles coming up. This hasn't happened before in the 3 months I have owned it. There was even a "new" smell  when I opened the cover.  I'm not even sure how to get the panel door off....I took off 2 screws, but can't seem to get it open. Should I turn the power off until I figure out what it is? THIS is when I hate being single....this and car problems!!!
Title: Re: Help please....Jetsetter acting funny!
Post by: Chad on January 04, 2007, 12:00:07 am
MLG, is the smell kind of sweet and are the bubbles really small?
Post by: MostlyLurkingGal on January 04, 2007, 12:01:34 am
yes and yes
Post by: hottubdan on January 04, 2007, 12:03:47 am
It sounds like an ozonator, which could have been installed any time.  Why it has only started bubbling now is a mystery.
Don't worry about it.
There should be 4 screws to remove to get the door open.  Stick with it. :o
Post by: Chad on January 04, 2007, 12:05:35 am
Sounds like you have an ozonator afterall. That's weird for it to just come on like that. Are bubbles constant or do they come and go? Can you hear something running when the main pumps and heater are off?
Post by: Gomboman on January 04, 2007, 12:14:43 am
MLG, what a great X-mas gift. Maybe your ozone system was plugged and now came back to life. If it smells like fresh watermelon it's ozone. Get in the spa and take a light whiff.
Post by: MostlyLurkingGal on January 04, 2007, 12:15:26 am
Thanks guys....I'm a little concerned because this hasn't happened before. I will try tomorrow to get the panel off....not sure what I will do once it's off tho...lol
The gurgling (that I have never heard before) and the bubbles are constant right now.
The hot tub was very quiet until this started sometime today.
Chad, Normally when the main pumps are off...the heater is on, so I don't really know how to answer that. If it is an ozonator, is it suppose to gurgle??
Anyway, I have to hit the sack......I sure appreciate the help, and I will check this thread first thing in the morning!
Post by: MostlyLurkingGal on January 04, 2007, 12:17:29 am
Hey Gomboman...that's exactly what it smells like!!!!!
Post by: Chad on January 04, 2007, 12:18:01 am
Yes.
Good night and good luck tommarrow. :)
Keep us posted.
Chad
Post by: MostlyLurkingGal on January 04, 2007, 12:21:07 am
Thanks so much guys.....I was worried about going to sleep and leaving it on. I AM a bit concerned about the "gurgling"...but maybe by tomorrow it will stop working again and all will be silent...LOL
Post by: Gomboman on January 04, 2007, 12:24:17 am
MLG, you might want to clean out your ozone system.
http://www.inlandhotspring.com/ozonecleaning.htm
Post by: MostlyLurkingGal on January 04, 2007, 12:27:07 am
Ohhh excellent link....thanks! Now after work tomorrow, when I figure out how to take my panel off, I now know what to look for!!
You guys are the best.....Thanks so so much!!!!!!!
Post by: hottubdan on January 04, 2007, 12:59:02 am
Another trick is to add an enzyme product like Spa Perfect to the filter compartment with the jets off.
Post by: Gomboman on January 04, 2007, 01:04:09 am
hottubdan, I'm assuming you're talking about adding an enzyme product to reduce the gurgling noise? How exactly does that work?
Post by: MostlyLurkingGal on January 04, 2007, 09:28:41 am
Still bubbles....still gurgling........
Post by: shortspark on January 04, 2007, 10:16:01 am
I will be getting a new Jetsetter at the end of the month.  Will it have an ozonator?  What exactly is an ozonator?
Post by: hottubdan on January 04, 2007, 10:47:36 am
My understanding is sometimes the gurgling is related to the circ pump getting clogged.  Enzymes break up enough for a better flow.
Post by: hottubdan on January 04, 2007, 10:49:40 am
Which style Jetsetter are you getting?  There is the Classic series which does not have an ozonator as standard equipment, and what we call the Luxury series which does.
I will let someone else explain what an ozonator is and what it does.
Post by: Reese on January 04, 2007, 10:56:57 am
The description of a new bubble source, and a sweet smell certainly sounds like ozone.  Perhaps there was a clog in the delivery line that cleared itself.  The gurgling could be as simple as this new source of air collecting into large bubbles in the return line.  I seem to recall a thread about gurgling in HotSpring tubs way back in the archives.  I thought diverter valves were involved, but I don't really remember.  Perhaps a long search (700 days) on "gurgle" or the like would yield some results.
Post by: East_TX_Spa on January 04, 2007, 10:58:09 am
Shortspark is getting an '07 Luxury Jetsetter with standard Freshwater III Ozone.
The ozonator is a supplemental water care system that allows you to use very little chlorine in the spa and makes taking care of the spa a little bit easier.
Terminator
Post by: shortspark on January 04, 2007, 11:25:33 am
Terminator
Thanks Term.  I'll find out more about this thing next time I get to Longview as we may not have discussed it fully last time.
Post by: MostlyLurkingGal on January 04, 2007, 07:01:33 pm
Well....I looked and lo and behold I have an ozonator!  ::)Go figure! I was barely getting the hang of what to do chemical-wize with no ozonator, and now I have to figure out what to do with one.... Do these things run 24/7?
Thanks for all the help you have given me!
Post by: Spatech_tuo on January 04, 2007, 07:03:56 pm
Ozonators run when the spa is filtering. Since you have a spa with a circ pump that filters 24/7, you get ozone 24/7.
Post by: hottubdan on January 04, 2007, 07:26:50 pm
It should not significantly change what you are doing.
Did you see a brand or model name on the ozonator?
There are different types.  If you have a UV system, even if you are having bubbles you are probably not getting ozone.
Post by: MostlyLurkingGal on January 04, 2007, 07:45:41 pm
It is a HotSprings one, but that's all I noticed. Don't be confusing me more with that UV thing!!!! ;D
Post by: hottubdan on January 04, 2007, 07:55:52 pm
If it is a Hot spring one it is the CD ozonator...the good one that keeps going and going and going. :D ;D :D ;D :)
Post by: Tatooed_Lady on January 04, 2007, 07:58:47 pm
okay, so you have the 'energizer bunny' style....keep doing the same as what you have done prior to now with sanitizer, etc....and watch your test strips (or taylor kit or whatever) to see what the difference is....you may get away with using a touch less sanitizer, but I believe that's about it?
Post by: hottubdan on January 04, 2007, 08:12:19 pm
Sounds right to me.
Post by: MostlyLurkingGal on January 04, 2007, 08:38:39 pm
I will just do a tad less of what I have been doing, and see what happens. Thanks!
One of my problems with boards like this is that I think I get too much information...for example, I read up on ozone now that I apparently have it and am now a little worried about breathing in the fumes...my hot tub is on my porch, and I read somewhere that indoors is not that great for ozonators. Maybe too much information is not always a good thing? ;D
Post by: Gomboman on January 07, 2007, 12:32:48 am
MLG, did you find out what type of unit was installed in your Jetsetter? Do you have a FWIII, FWII, or something else? There should be a label on the ozonator.
Post by: MostlyLurkingGal on January 07, 2007, 12:48:46 am
it's a FW but I didn't notice if it was a II or a III :-/
Post by: hottubdan on January 07, 2007, 10:41:34 am
Was it a big black box or a small black box?
Post by: MostlyLurkingGal on January 07, 2007, 11:03:56 am
dan,dan,dan........now you know size is subjective...what I might think is small, you might think is big ;D
Post by: Richs100 on January 07, 2007, 11:07:30 am
MLG,
I don't think you have anything to worry about, but the sudden appearance of bubbles that weren't there before is curious.
My 93 Prodigy bubbled and gurgled the entire 12 years I had it.  That was with a working ozonator and after I had removed it from the tub when it stopped working.  I kinda liked it and considered it my "water feature". :)
(My new Envoy bubbles, but doesn't gurgle)
Get it checked out just to know if you have an ozonator, and if it is working, but in my own (uninformed) opinion, I don't think you have a problem that could damage the tub in the immediate future.
Post by: MostlyLurkingGal on January 07, 2007, 11:18:34 am
MLG,
Richs100, I looked and I DO have an ozonator.....apparently an aftermarket install as the 2005 didnt come with them. (I bought this tub from a private party) It just started all on it's own a couple of days ago. It concerned me at first because at the time I didn't even know there was one...and it was gurgling, where before it was perfectly silent....which was VERY nice. So I'm not really "concerned" anymore...just miss my silence when I sit with the jets off. No biggie tho!
Post by: Gomboman on January 10, 2007, 11:46:38 pm
MLG, the 2005 models did come with the FWIII--as an option. I'm sure that's what you have. I was thinking you had an older spa.
Post by: MostlyLurkingGal on January 10, 2007, 11:58:18 pm
Yep, I'm sure that's what I have......and it's still working.....go figure! ;D
Post by: galen on January 11, 2007, 12:28:17 am
My tub's ozonator quit working after a few months of operation. I opened the side panel and looked at the box. I took the clear plastic hose off that had several loops and two plastic check valves in the line. I could see a yellowish gunk inside the line. I took the check valves off and flushed them  several times. I found that one of the little check valves was stuck and wouldn't open. After forcing water both ways it finally released and started working. Put the clean line and checks back on and watch the little bubbles coming from the opening at the bottom of the tub. The flow is much more now. And I can smell it. I read somewhere that the ozonator builds up a residue in the line after a period of time.
