Original => Hot Tub Forum => Topic started by: wmccall on December 15, 2006, 06:28:57 pm
Title: I'm sticking with Nature2
Post by: wmccall on December 15, 2006, 06:28:57 pm
ITs been a one year test I bought 3 Nature2 packs on Ebay for $45 last year and used each one for 4 months as directed.  Its totally unscientific, but I say for certain, my water conditions the past year have been the best over. When I did my last change in early November the water was just over 3 months old, but it looked as crisp as new. I ony changed because I feared if a cold snap occured I wouldn't have the opportunity to do so again for awhile.
It could be argued that having owned my tub for more than 3 years now I am more experienced in water care.  But I think I'll keep using it for another year, I just bought 3 more.
Title: Re: I'm sticking with Nature2
Post by: hottubdan on December 15, 2006, 08:09:51 pm
A round of applause for Nature2 ;D :D ;) :)
Post by: LtDan on December 15, 2006, 10:33:30 pm
How does it work? Similiar to bromine or chlorine (or neither)? If it's easy, I'm all for it. I think you should change your water again this week, apparently it ensures warm weather!
Post by: Tman122 on December 16, 2006, 05:50:29 am
N2 is a mineral cartridge that is inserted in your filter to allow for water flow past it. The minerals supplement a good chlorine regimen and give you a bit more leway allowing you to (being carefull how I put this) adjust your chlorine additions between uses.
Post by: LtDan on December 16, 2006, 09:59:44 am
Thanks Tman, I did have a spa frog when I first got my tub. I need to try another now that I have got the hang of things.
Post by: tony on December 16, 2006, 10:55:30 am
I am with you, Bill.  I feel it actually does more for your water than ozone.
Post by: txwillie on December 16, 2006, 10:59:21 am
is N2 similar to the SpaFrog?
txwillie
Post by: tony on December 16, 2006, 11:01:43 am
txwillie
Very similar.  The Frog is silver and limestone while N2 is silver and copper.  In both cases the silver is main ingredient.  Your can use the Frog with bromine or chlorine, N2 only chlorine.
Post by: txwillie on December 16, 2006, 11:09:03 am
Hmmm.....
Had a Marquis with built in SpaFrog and Bromine cartridges. Had less than stellar results with bromine. Di-clor and no frog worked better for me
Post by: tony on December 16, 2006, 11:14:24 am
Hmmm.....
I'm not crazy about the built in cartridges nor the double floater they sell.  I like the oringinal in the filter compartment with your normal bromine system.  You could also use it with the two part bromine system if you like.
Have you tried dichlor with a frog or N2?
Post by: anne on December 16, 2006, 01:03:20 pm
I dont have the length of experience that you do, but I would say that over my 3-4 month intervals with vs without N2 so far, I agree with your results. I never really tried to add less chlorine, but my water is easier to balance, and I can go at least a couple of days with no use/no chems added, and not worry at all. Granted, the ozone is part of the equation, but I'll be buying N2 again.
And a 3 pack for $45? Love you, Doc, but I may be checking out Ebay!!!!! ;)
Post by: bosco0633 on December 16, 2006, 02:50:47 pm
can you use it with bromine tubs???
Post by: tony on December 16, 2006, 02:53:07 pm
You can use a Frog with bromine tubs.  You cannot use N2 with bromine.
Post by: bosco0633 on December 16, 2006, 02:55:38 pm
what exactly is the frog Tony and how does it work with my bromine?
Post by: Tman122 on December 16, 2006, 03:08:51 pm
The frog is a mineral cartridge just like N2 but instead of silver and copper ions like the N2 it uses silver ions and limestone ions to help fend off bacteria. It goes inside your filter cartrdge to facilitate precipitation of it's ions into your water.
It may allow you to turn your feeder down a notch.
Post by: tony on December 16, 2006, 03:14:24 pm
The Frog is a mineral purifier manufactured by King Technlolgy and also distributed by LeisureTime Spa chemicals.  It is similar to Nature2, except that the makeup is such that the Frog can be used with either bromine or chlorine while Nature2 can only be used with chlorine.  I started with the Frog through LeisureTime because that is what my dealer supplied.  When Sundance introduced the SunPurity, I switched to that.  SunPurity is made by Nature2 and is nothing more that a Nature2 cartridge manufactured in a shape to fit the Sundance bromine compartment.
You can check both N2 and the Frog at Doc's site.  He sells both.  King Technology itself is at www.kingtechnology.com.
Post by: wmccall on December 16, 2006, 05:42:53 pm
Its as easy as throwing it in the filter compartment for me. Other than that, I don't do anything different.  Some percieve it to be a replacement for bromine or chlorine. Some say it allows you to use less of those products.
Post by: wmccall on December 16, 2006, 05:46:16 pm
I have never tried The Spa Frog.  There was some discussion here stating that the cartidges are not refillable and there was discussions on how to do so.  I heard through back channels that the people at King were not happy about that and wanted it to go away. (You might guess how I reacted to that  :P
Post by: Tman122 on December 17, 2006, 05:19:22 am
Tony.....you scare me...knock it off.
I don't think I have a twin brother???
Post by: tony on December 17, 2006, 10:32:52 am
 ;D ;D ;D ;D ;D
I think we've had this discussion before, Tman.  Thats what happens when you become an old timer here.
Post by: Tman122 on December 17, 2006, 11:46:20 am
 ;D ;D ;D ;D ;D
Old timer.....I represent that remark!!!
