General => General info Somewhat hot tub related => Topic started by: Johnny D on May 24, 2007, 10:28:28 am
Planning on getting a Maxxus and noticed that the electrical is designed to enter thfrom the outside on either of the front two corners. Â I'd like to come up from underneath and stub up a piece of conduit when I plan the pad install to eliminate seeing it. Â
Any problem coming up from underneath that I should be aware of?Thanks in advance.
jd
This needs to be moved to the main forum as it is 100% hottub related.
As long as you open up the Maxxus you are going to get and do the correct measurements, there are no issues with coming up through the bottom.
have a Maxxus and also came up from the bottom. I came right through the bottom frame member on the right hand side. No probs and worked great!
Thanks, Will have to stop by the dealer and see exactly so I know where to stup it up before I set up the patio. On the other hand having it come up the side has its advantages.
Thanks for responding
