Original => Hot Tub Forum => Topic started by: Styx555 on August 15, 2006, 01:59:37 pm
Can someone shed some light on the types of full foam available and the benefits to each?
Some foams are denser than others. A denser foam will provide a higher R factor. I belive the density is measured in weight per cubic foot. Hotsprings uses a 2lb foam.
Closed cell versus open cell. Closed cell foams can trap and retain the heat better than an open celled foamed. Cells refer to the actual "partilcles" of foam. Open celled foam is usally soft and spongelike. Closed cell are denser, harder, and heavier.
You would want a high density closed cell foam for insulation over say, stryofoam. ;)
If considering a full foamed tub, one that has the entire structure (except for the motor compartment fill completely with the foam. This would be from the hot tub skirt (outter wall) to the shell of the tub. No gaps, no areas that have none.
Some lower end tubs use a lighter foam, or do not completely fill the cavity with foam. Tubs like this should be avoided.
Does anyone know where I can see pictures showing the differences, so that when shopping I know what to look for?
just get it over with and buy a HotSpring or Tiger River. ;) No seriously, I just did a google search, "full foam spas". Of course, the spa vampire's hot air site came up, but a bunch of others did too. Didn't look through them all, didn't see any pics. Buy a spa from the dealer who makes you feel the best. Gut instinct, follow it.
I think the density of the foam is minimumly important in determining R-value.
The more important thing is open or closed cell. Not for heat retention :-? but because closed cells are just that. Closed. The can't absorb moisture. You dont wan't a sponge(open celled) under your cabinet.
Actually, Hot Spring uses varying layers density foam. They go from a 60 lb foam down to a 2 lb foam. They also use all closed cell. You must have closed cell or else you can get too much water absorption. Some mfgs who are on the lower end will say they are full foam but use an open cell foam. Be careful when looking at those. Stick with brands like Hot Spring. You know they used closed cell and do it correctly.
