Original => Hot Tub Forum => Topic started by: davidg on August 07, 2006, 12:23:28 pm
Would you recommend a 50 or 60amp hookup for the Bahia? One Sundance dealer says 50amp and another says 60amp. I guess with a 50amp, you can't have all the jets on and the heater at the same time. The 50amp person said if I plan on keeping the water around 101 degrees or so, the heater usually doesn't need to be on with the jets.
What power have you used?
Thanks.
I would go with the 60 amp. That way if the heater DOES need to be on with both jets on, then it can be.
Thanks for the 60amp suggestion...that's what I was thinking.
I was also wondering if anyone has been running it on 50amp, what their experience was.
I run my Optima @ 60 amps. There was no cost difference to me, so in my case it was a no brainer. My 60 amp GFI breaker was actually about $15 cheaper than the equavalent 50 amp one. I live in Minnesota, so I figured it'd be nice in winter to have the heater on whenever it needed to be.
I run my Optima with at the factory set 50 amps. I have never had as issue with the heat keeping up, even during winter (MA). I do agree, though, that the 60 amp setup is best.
