Original => Hot Tub Forum => Topic started by: glastron on August 05, 2006, 09:58:59 pm
Title: marquis ozonator
Post by: glastron on August 05, 2006, 09:58:59 pm
well can anyone tell me what type of ozoneator my marquis tub has i know the light is purple is all oh and marquis must have done some testing on these before factory installing them also ul approved anyone know how to obtain any of their test results?  thanks
Title: Re: marquis ozonator
Post by: DPS on August 05, 2006, 10:38:43 pm
The ozonator used by Marquis is a plasma cell ozonator.
The unit is solid state, so there is no ballast and starter and it puts out a consistant level of ozone for a very long lifespan.  The estimated life is 10-15 years with no degradation (per the manufacturer).
The ozone is introduced into the water via a Mazzei injector and then goes through a contact chamber to keep the ozone bubbles in contact with the water as long as possible.  This makes for an extremely efficient system and passes U.L. standards for zero offgassing.
Post by: Mendocino101 on August 05, 2006, 11:12:55 pm
Yes the very nice thing about the Marquis unit is it is not your standard UV type and seems to have solved what was the UV bulbs shortcomings by using the a plasma cell to fire it up and thus producing a consistent and reliable flow of ozone and in simulated testing was shown to work for 7 years with no drop off in its out put.
Post by: MarKee on August 06, 2006, 01:53:56 am
Tests were done on the Marquis Q3 ozonator and it performed flawlessly after being turned on and off 100,000 times.
Post by: Gomboman on August 06, 2006, 02:00:09 am
I'm just curious why Marquis doesn't use a CD ozonator. Is it for cost reasons or does Marquis believe their method is technically superior?
Post by: MarKee on August 06, 2006, 03:06:39 am
A CD ozonator eventually requires maintenance.  The Marquis ozonator has a purple glow to it that lets you know that it is on, it is either working 100% or it is not working at all, never any maintenance.  I doubt it is a cheaper unit, Marquis has never been known to use an inferior component in order to cut costs.  As DPS said in an earlier post, when an ozonator goes out, the customer usually notices it because their water chemistry turns to crap.
Post by: Mendocino101 on August 06, 2006, 12:42:32 pm
I'm just curious why Marquis doesn't use a CD ozinator. Is it for cost reasons or does Marquis believe their method is technically superior?
No not at all....One this unit is UL approved as is their total spa and two....They believe it offers the best in ozone....that's not to say CD units are not good....but they feel this offers a unit that is compatible with their goal offering a customer a spa that might have less 'showroom flash" but lasts in a backyard with minimal maintenance from the owner....
Post by: Gomboman on August 06, 2006, 02:37:35 pm
Ok, very nice. It sounds like the Marquis unit will last longer than a typical CD ozonator.
Post by: Mendocino101 on August 06, 2006, 04:02:43 pm
It does have a 3 year factory warranty and again in testing been shown to last for 7 years with no measurable drop in ozone output.... CD units many will require a chip replacement.
Post by: hottubdan on August 06, 2006, 11:09:22 pm
Only those that use the chip technology.
Post by: Gomboman on August 06, 2006, 11:12:23 pm
Does HS use a chip? What is the life expectancy of a typical HS CD unit?
