Original => Hot Tub Forum => Topic started by: Neohcouple on February 16, 2006, 09:28:10 pm
Title: High ALK But Good PH
Post by: Neohcouple on February 16, 2006, 09:28:10 pm
My PH is perfect at about 7.6.  However, my ALK is close to 300.  Any suggestions on lowering the ALK without lowering the PH.   I'm afraid if I use PH down which should bring the ALK down, it will also cause the PH to come down.
I use chlorine for my HS tub along with an ozonator.
Title: Re: High ALK But Good PH
Post by: Tatooed_Lady on February 16, 2006, 11:27:55 pm
Oh, boy......I've read a lot of info on this sort of thing.....I don't think throwing a sea bass into the tub would help....I see there's a product to INCREASE alk, but I didn't see something to lower it.....
Anyone?
Post by: Nitlion15 on February 17, 2006, 08:33:42 am
I've got a very similar problem.  I've got high Alk and a PH about 7.2.  I was concerned about using PH down to lower Alk.
Dealers and Hot Tub Guru's, please help us newbie neophytes...... We are  ??? :-/
Post by: Brewman on February 17, 2006, 09:02:56 am
My tap water is fine Ph wise, but way high, over 400, for alk.  So I have to add about 20 ounces or so of Ph decreaser when I refill the spa.  Yes, it does lower the Ph along with the alk., so then I just add a little Ph increase to push the Ph back up.
Using bromine and MPS tends to drift both down over time, so I have to add small amounts of Ph increase and or alk increaser over time.
There is Ph increaser, which increases Ph, and Ph decreaser, which decreases both alk and Ph.
And there is alk increaser.
I have not see a product specifically sold as alk decreaser.
Alk increaser is sodium bicarbonate, which is exactly what baking soda is.  So that's what I use.
Post by: wmccall on February 17, 2006, 10:34:39 am
Trying using an ounce of White Vinegar. It will lower your PH a little, but the alk even more.  You might have to settle for the PH in the low range of acceptable to get the alk at the high end.  A Ph of 7.2 is still good.  How old is the water?
Post by: Brewman on February 17, 2006, 10:39:06 am
I wonder what'd happen if you put vinegar and baking soda into the spa together?
I seem to recall Mr. Wizzard (remember his show?) doing this once- result was rather interesting.
(Not that you'd add those quantities to the spa)
Post by: cappykat on February 17, 2006, 10:56:04 am
How often should a refill be done?
I use bromine and MPS.  I forgot to add the shock one week and the next time I checked the ph and alk were very low.  I got them back up by adding 3 oz of ph up and 3 oz of baking soda.  Then I added 2.5 oz of mps.  Now the bromine level is in the high range.
Post by: Brewman on February 17, 2006, 11:42:27 am
I change my water about 3 or 4 times per year.
That's just my rule of thumb, it can vary based on frequency of use, and other factors.  You'll know when it's time- water isn't quite as sparkly clean, gets harder to balance, etc...
It can be challenging to get bromine to level itself out.
I've noticed the same thing- Shocking shoots up the reading on the bromine level.  I just pull the floater for a day or two and it drops a bit.  So will using the spa- just don't get in if the reading is super high, I've been told.
That's why I intend to switch over to dichlor on my next fill- based on what I've read here, dichlor users seem to have the easiest time keeping their water maintained.
Post by: cappykat on February 17, 2006, 01:01:27 pm
Brewman...I've got 5 bromine cartridges to use and then I'm going to consider doing the same.  So with dichlor do you just put it in a floater?  When you change you'll have to let me know what you're doing and how it is.
Post by: orlandoguy on February 17, 2006, 01:28:39 pm
I have also decided to give dichlor a try on my next fill.  I am doing this mainly because of the itching that I am experiencing at night after a soak before bed, even after a long shower.
I currently use a bromine floater but am under the impression with dichlor, it's simply a teaspoon after each use then it is barely noticeable next use, right??
Post by: Brewman on February 17, 2006, 01:45:55 pm
My bromine routine is similar- except that I the bromine I use looks more like chunks of broken chalk, vs the tablets, but I still use a floater.
Dichlor isn't dispensed with a floater- it's granular, and you'd measure out the desired quantity and add it to the water.  Make sure you don't use chlorine pucks (trichlor), that's for swimming pools, and will often void a spa warranty.
From what I've read, there are a couple ways to administer to a dichlor tub- I'm gravitating to the method referred to as "Vermonter's" method, named I think, for a someone who contributes to Doc's website.
In fact, his routine can be accessed from Doc's.
It involves dosing the spa after use, allowing the chlorine to be at a low level when you actually use the spa.  With dichlor dosing in between if you don't use the spa regularly.  Still need to use either MPS or dichlor for shock.
I'll certainly let you know how it goes.  I'll be changing my water as soon as the weather starts to warm up.
Right now it's below zero- bleech. ( Guess we're paying for that warm January we got away with.)
Post by: cappykat on February 17, 2006, 03:18:55 pm
We don't use our tub regularly.  Maybe 2 times a week and sometimes not even that.  The thing with the cartridge is I never know when to change it.  Instructions say 2-3 weeks but if I'm not using the tub regularly then I can't believe it's that often.  I haven't changed it since 2/21 and I had a high bromine reading just Wednesday??
So if I'm not using everyday and I switch to dichlor, what would my dosing schedule be?  I shock once a week with mps now...I guess I would continue to do that and just dose with dichlor after we use the tub?
Post by: Bonibelle on February 17, 2006, 03:34:57 pm
Cappy, we (at least my hubby) use the tub very often but I also have problems with that darn frog and knowing when to change it. It's hard to tell if it is empty even when you fish it out. Then the bromine goes flying up...I was thinking of switching too but after talking to my dealer, decided to stick it out a while longer. Last week I started adding Spa perfect (I think Stuart mentioned it on here too). I use it in my pool (pool perfect) and the family swears that it conditions the water and it feels silky. I really believe it helps the spa too. I added the second dose yesterday and I feel the difference. The water doesn't seem to dry my skin as much.  I don't get that rough groaty feeling when my hair gets wet either. (I really don't like the spa water in my hair) Well see....
Post by: wmccall on February 17, 2006, 05:09:46 pm
In case I didn't stress the point enough, there is no perfect PH.  7.2 is just as perfect as 7.6   I call 7.2-7.6 the "ideal range"   If you can lower your PH to 7.2 and have the Alk at a more reasonable number then you win.
Post by: MarKee on February 17, 2006, 10:07:08 pm
Chlorine tends to work better in lower temperatures, for instance pools.  Chlorine will off gas at 98 degrees, bromine off gasses at a much higher temperature.  Chlorine works but you will probably notice more of a smell in the spa.  Some people are also allergic to chlorine.  Keep in mind you will rarely have "perfect" chemistry in your water, you just don't want the pH or alkalinity to be too far off the scale in either direction.  If you constantly test it and try adjusting it, you will drive yourself crazy.  Test and adjust it once a week.
Marquis owners using SpaFrog cartridges:  In the next few months your dealer will be selling a new bromine cartridge that will last longer, it will be green.  The price should be fairly similar to the yellow ones, so it will be a nice improvement to the system.
Post by: IDW on February 21, 2006, 11:51:21 pm
Ph down should not be called Ph down. It should be called dry acid because thats what it is. Acid will do one of two things depending on how you add it. To lower alkalinity you most pour it it one spot to form a column of acid.This will destroy Sodiun Bicarb. Alkalinity is the measure of sodium bicarb. Broadcasting it across the serface will lower the ph. You cannot do both things at once.
Chlorine is not meant for spas unless they are below 98 degrees. Why Dichlor? It is stabilized. Lithium chlor is better for those that insist on using it
Post by: cappykat on February 22, 2006, 09:15:26 am
Hey bonibelle...just read your post.  I finally decided to break open one of the used cartridges I had kept....and found there was still bromine in it!!  That's another thing I dislike about them...you can't tell if they are empty!
I'll see if I can find that Spa Perfect and give it a try.
Post by: SerjicalStrike on February 22, 2006, 09:21:54 am
How big does the "column of acid" need to be?
Wide? Tall?
Why is "Lithium chlor" better for spas than diclor chlroine?
Post by: IDW on February 22, 2006, 05:15:31 pm
The column of acid needs to be small enough not to hit the bottom of the spa or a vinyl liner in a smimming pool. In a spa it will take a few applications to lower alkalinity. I would need to know the capacity of the water, the ph and the alkalinity to give you the proper dosages. The spa must be off to destroy sodium bicarb(alkalinity). The pumps should be running full when adjusting ph.
Dichlor is stablized with cynaric acid. There is no reason to put stablizer in a spa. High stablizer will make alkalinity test higher than it actually is
Lithium is unstabilized.
Post by: tony on February 22, 2006, 07:52:56 pm
Although dichlor is stabilized and there is no need for CYA in a covered spa, it has a far more neutral pH than lithium and you will use much less because dichlor has a much higher concentration of chlorine.  Lithium is OK for spa use, but IMO it is second to dichlor by a long shot.  CYA buildup in water will tend to reduce the effectiveness of chlorine, but with the small amount used on a regular basis and the fact the you change water every three to four months, it does not become an issue.  With lithium, your TDS will increase much faster.  When you weigh CYA vs TDS, the amount of product used, the cost, the pH....dichlor comes out on top...IMO.
If you are interested in an in depth discussion regarding dichlor dosing, I would suggenst, as it has been earilier, that you go to the rhtubs.com forum and go to the FAQ section and read Vermonter's dichlor dosing and Northman's routine.  It is a great place to start.
Post by: ssbraun on February 22, 2006, 08:02:03 pm
I'll go along with Tony...I used lithium hypochlorite for a while and had HUGE ph issues...went through a lot of acid :o...switched to dichlor and ph is steady...small "ph up" dose every week or so.
