Original => Hot Tub Forum => Topic started by: st18901 on November 18, 2005, 10:47:10 pm
Chas (or anyone else)
You mentioned that the wood was still available for the skirt of the 1986 HS sovereign... how do I find out more info on that?
Do you have a price?
I'm specifically in need of two pieces that go on the equipment door - the center vertical piece and the bottom left side.
Thanks.
I think the two part #'s you need are 32564- $11.80 and 32503- $41.20. Just call the local HS dealer and they should be able to order them for you.
Hope this helps.
Terminator
thanks a lot, Terminator.
Methinks, I'm going to buy some 1/2 inch redwood and do a little routing.
