Original => Hot Tub Forum => Topic started by: clayfiregrrl on October 10, 2005, 08:45:00 pm
Title: Fill Hot Tub With Hot or Cold Water?
Post by: clayfiregrrl on October 10, 2005, 08:45:00 pm
Hi, our 2005 hot tub (HS/Tiger River Caspian) is being delivered tomorrow (hurray!), and although our electrician is not available for another two weeks :-[, we are already thinking about how to fill the tub once the electrical work is done.
Is it best to just fill the tub with cold water from the garden hose and then heat it in the tub or to fill it with hot water from the sink (a friend of mine said that's what she does with her hot tub) so that it does not have to heat as long in the hot tub or does it really even matter?  Cost wise, it seems to me it would be a wash (no pun intended).
Also, another friend told me tonight that she thought the fire department could be hired to fill a pool or hot tub with water...is this true?  Has anyone ever done this and if so, what does it cost and is this a good idea or are there other issues with this approach?  I've never heard of such a thing...
And my last question about filling the hot tub (at least for now!) is do we start filling the hot tub with water the day before the electrician comes or do we wait until the electrical work is done to start filling it?  Was told we should not have standing water in the tub but not sure if the electrician needs it filled to test the connection???  What is the optimal sequence of events on this?
Thanks and happy hot tubbing to all!
Dorie
Title: Re: Fill Hot Tub With Hot or Cold Water?
Post by: Neohcouple on October 10, 2005, 09:21:33 pm
Fill it with cold water only.  I just refilled my HS Vanguard & the owners manual clearly states cold water only.  It only took about 5 hours to heat up to 100 degrees.
Post by: twok99 on October 10, 2005, 10:50:46 pm
During the warmer months (April through Oct) I use my garden hose.  When it is colder and especically if I am filling in Jan-Feb I run a hose from my basement sink and mix hot and cold.  The mix results in water in the mid 60's (my straight cold is 36-38 in the winter).  I think the mix is fine, I would not use straight hot water nor and get a mix so my water ends up at 100.
Post by: Cola on October 11, 2005, 12:04:22 am
You should fill the tub ta day or two before the electrician arrives, that will be fine.  It will take about two hours.  Your hot water tank is about 10% the size of the hot tub so unless you run a mix of 20% hot and 80% cold, the tank will go cold in about 10  minutes.  Straight scalding water could damage the tub.  Lastly, the fire department likely doesn't want to be bothered filling swimming pool.  The public works department might do that but I wouldn't want to pay some union guy to stand around and watch my pool fill up.
Good luck
Post by: Spatech_tuo on October 11, 2005, 01:43:58 am
You should fill the tub a day or two before the electrician arrives, that will be fine.
It generally only takes about 45 mintues to fill a spa. I would NOT fill the spa until the electrician agrees. If he wants to move it even a little it needs to be empty. Based on his progress, I'd start filling it about an hour from the time he anticipates being done.
Post by: Brewman on October 11, 2005, 08:52:56 am
Most household water heaters are 40 gallon to 50 gallon.  Filling with hot water would just be wasteful- you'd empty your tank in pretty short order, and you'd be without hot water in the rest of your house.
Let the spa heat the water, that's what it's for.
Also, if you have a water softener in service, you don't want to put softened water in your spa.  A mix of soft with non softened may be ok, but straight soft water isn't recommended without adding a supplement.
It's likely that if you do have softened water, all hot taps are connected to it.
Post by: stl-rex on October 11, 2005, 09:01:13 am
We filled ours in about an hour (540 gallons) using the access point in the basement before the water hits the regulator.  Both of our outdoor spigots are post regulator and have significantly lower pressure.  Personally I'd fill it the day he's due to arrive.
Post by: marks on October 11, 2005, 09:50:59 am
I agree with Spatech.  Wait for the electrician. We had to move our spa about 2 inches, if it was filled with water it could not have been moved.
Post by: Rayman on October 11, 2005, 09:56:40 am
It doesn't take long to fill up the tub, wait for the electrician.  Have the hose ready and as soon as he/she says it's ok then turn it on.  45 minutes and it will be ready to go, probably before the electrician is ready to leave.  Fill it up with cold, moine is 400 gallons and it took about 6 hours from 62 degrees to 100.
Ray
Post by: drewstar on October 11, 2005, 10:38:21 am
It doens't take too long to fill the tub.   I would fill the tub from an outside spigot or the cold water tap. Filling it with hot water is a waste, and as mentioned scalding water could damage the shell.
I'd be hestient to have the fire department fill it. Don't they just take water off the hydrant? Water from a hydrant can be very, very rusty and create huge problems.
Post by: Chas on October 11, 2005, 12:39:19 pm
One thing that hasn't been mentioned:
DO NOT turn on the power unless/until your Tiger River spa is full of water. You can ruin the circ pump by running it dry, and it is silent, so knowbody will notice it happening. The heater now has a pressure switch to keep it from running dry,' but the circ pump and jet pumps can be damaged very quickly by running dry.
Also: there is a tip which I think has finally made it into the owners manual about turning on the breakers. You need to turn on the 30 amp first, and wait for everything to settle. Run the jets for a few minutes, shut them off. Look at the surface of the water: when it is calm again, you should be able to see the water moving a bit directly above the floor fitting. This indicates that the small circ pump has caught its prime and is ready for you to power up the heater - that is - turn on the 20 amp breaker.
And one more item: as you fill the tub, do so through the core of the filter. Take off the cap, run the hose on the ground for a half minute or so, then put the hose into the filter core and fill the tub from there. That will help to prime all systems.
I put cold water in my spas at home, but I have rigged up a hot water tap in the showroom to help speed the heating process. It is not soft water, it is clean water, and I add it carefully to avoid overheating the spa. It's a lot of work - run the cold first to put about a foot or so of water, then run the hot and cold together, wait 20 minutes for the heater to reheat, then run it again, while holding an accurate thermometer in the tub to keep an eye on the mix of hot and cold water.  I only do this if I have a customer coming in right away or if we had to do a water change during open hours - wet test by dirty people....
Post by: tootsie on October 11, 2005, 12:51:38 pm
regarding the fire department,  In this area we have a volunteer fire department and they fill pools for a predetermined donation (and you could always give more) kind of for a fund raiser thing.  We didn't need to use it so I never checked any farther into it, and I don't know if the fill from town water or a pond.
Post by: drewstar on October 11, 2005, 01:00:17 pm
Using the fire department, even if it's clean water (not from a rusty hydrant), would be over kill.  Perhaps if you had a 20,000 gallon pool, it might be worht checking into, but for a 350 gallon hot tub, it's  absurd.
Post by: Brewman on October 11, 2005, 01:36:16 pm
Our FD won't do anything like that, even for large volumes like pools.  From our outdoor tap, our 500 gallon spa fills in pretty short order, under an hour, maybe even less.
The city does give residences a break on water rates for a window of time in late spring for those filling pools.  They pay the same rate for water as usual, but don't get as many gallons charged for sewer.  Usually they base sewer charges on metered water usage pretty much gallon for gallon.
Post by: SerjicalStrike on October 11, 2005, 02:13:06 pm
If your spa is delivered during the winter months, I would have the electrician turn on the spa for a few seconds (then shut it back off) just to make sure his work is correct.   Then start filling the spa.
Post by: tootsie on October 11, 2005, 02:47:57 pm
I 100% agree with brewman on water supply.
I should have stated we are on well water, and were concerned before we purchased the tub, if the pump and the well would be able to handle it, that's why we checked for alternatives in case there were problems.
Post by: rfraboni on October 11, 2005, 04:03:36 pm
I used the think the same thing as far as volume but I would be most of us use 20-50 gallons per shower, and more if we take a hot bath.  So for the volume of a few baths you are able to have a nice hot tub.
IF you are drought stricken at the moment it may be another issue.
Post by: Chas on October 13, 2005, 10:15:44 am
I would absolutely, positively NOT do this. See my post above.
Repeat: DO NOT do this. Fill the thing before you power it up.
Post by: clayfiregrrl on October 17, 2005, 09:50:41 am
Wow, thanks for all of the great info and responses!!  That all helps a lot.  I guess I was thinking it could take a day or so to fill up and then another day or two to heat and then god knows how many days to chemically balance, so couldn't figure out how to coordinate with the electrician (since I was thinking it could take up to a week to fill/heat/balance).  I am glad to hear it is all a lot easier and faster than I thought!
We definitely won't be calling the FD, will wait till the electrician comes before filling in case we have to move the tub (a distinct possibility), then will be sure it is filled (with cold water from our outside tap) before powering it up, testing the pumps, etc., following the sequence outlined here.
Thanks again!!!
Dorie
PS -- Our hot tub (HS/TR Caspian) was delivered last week and is sitting on our deck...the electrician is scheduled to be here one week from today...and we use city water (live in Ann Arbor, MI).   So if the electrician finishes by noon next Monday, perhaps we can be soaking in that hot tub by late Monday night or Tuesday night?  Woo hoo!!!!
Post by: Brewman on October 17, 2005, 10:03:59 am
Our spa (500 gallons) takes less than an hour to fill from the garden hose.  So even if you have slow water, you should be able to fill in a few hours.
Allow maybe an hour for each 4 or 5 degree temperature increase.
So maybe 8 hours to get to temps, so it's entirely possible you'd be ready for your first soak that same evening, for sure the next morning.
Post by: Backpains on October 19, 2005, 02:20:43 pm
I have a 300 gallon spa. It takes exactly 30 min to drain it with 5 syphoning hoses in and exactly 30 min to fill it with the outside spicot going full blast, by the time it's filled the temp is 59 degrees. It takes 5 hours to heat it to 100 degrees. I've not thought of doing the fill from the inside hot water tap but, I will say hubby has brought out 5 gallon buckets to the hot tub with scalding water and it hasn't bothered anything he just makes sure it's evenly distributed so you might want to think of doing it that way instead if your tub isn't far from your door.
Post by: Brewman on October 19, 2005, 08:15:23 pm
Wonder how much that helps?
With most residential water heaters holding 40 gallons,  and a few 50 gallons, you'd be putting 40 gallons of hot water in with 250 gallons of cold water.
Not sure what the temperature would equalize to, but maybe you'd gain 10 or 15 degrees?
Just curious.
Post by: Ruby on October 20, 2005, 01:08:28 am
I thought I read here not too long ago that one of the reasons you should't fill with hot water was because of the sediment at the bottom of the water heater possibly ending up in the tub.  I thought it was good reasoning so I quit doing it.  Since I stopped, I haven't noticed any difference in the time it takes to heat it.
Post by: Brewman on October 20, 2005, 08:26:15 am
If you take the water from the drain valve in the bottom of the water heater, there is a chance that the water will be full of sediment- that's exactly how you flush a water heater.  Some heaters get gunked up more than others so some water may be ok, some not.
Some water may be full of sediment that's not readily visible, so I wouldn't chance it.
But our water heater is over 6 years old, and I don't regularly flush it out so we probably would have sediment.
Post by: SerjicalStrike on October 20, 2005, 09:13:10 am
Would you rather turn the tub on for 3-5seconds (wihtout turning any of the actual pumps on) with no water in it and find there is a problem  or would you rather have a tub full of cold water and then find out there is a problem?
In the winter, with the water coming out of the hose at around 40 degrees, and the temps outside below 32, it doesn't take long for things to start freezing.
Post by: Brewman on October 20, 2005, 10:38:37 am
In our Optima owners manual, it says this is okay to do for very short periods of time (a couple seconds) to blow out any water in the plumbing.
Question- If I were to do this (I have not had to yet), would the flow switch keep the heater off?  I'd be more worried about burning out the heater by running it dry than by damaging the pumps by running them dry for a couple seconds.  I'm guessing that running the pumps without water could cause them damage if done for a long enough time period- but that's just me guessing.
Post by: SerjicalStrike on October 20, 2005, 10:54:57 am
The flow switch would keep the heater from coming on.
Post by: Perk1 on October 20, 2005, 11:54:48 am
Hey Chas,  I was under the impression that I should turn on the 20 amp breaker first, prime the pumps,than turn on the 30 amp but you list it the complete opposite.  Have I been doing it wrong?
EDIT - I just downloaded the 05 manual. It seems they have switched the configuration so the 30 amp breaker now controls the jet pumps and circuit board.  I am pretty sure in my 02 Landmark the 20 amp breaker controls these functions.
