Original => Hot Tub Forum => Topic started by: Rayman on June 10, 2005, 10:40:10 am
Title: water evaporation
Post by: Rayman on June 10, 2005, 10:40:10 am
How much water will evaporate each day if the tub is not used.  I am trying to figure out if I have a leak.
Ray
Title: Re: water evaporation
Post by: JcDenton on June 10, 2005, 10:43:22 am
If the cover is not removed I would think that there should be little or no real evaporation from the tub - not enough that you would notice in a short period of time.
Jc
Post by: Rayman on June 10, 2005, 10:53:05 am
it's about 2 centemeters, 3/4 inch in 24 hours.  The cover has been on and there is a puddle at the low end of the concrete.
Post by: JcDenton on June 10, 2005, 10:57:58 am
Sounds like you have a leak my friend.
Isn't your tub brand new?
Post by: Rayman on June 10, 2005, 10:59:40 am
1 week, they want to take it back to there shop and pick it apart for signs of a leak, I would rather have a new tub.
Post by: JcDenton on June 10, 2005, 11:02:14 am
That's unfortunate.
Can they not send a tech out to your house to address the problem?
Is your tub FF?
Post by: Rayman on June 10, 2005, 11:14:59 am
Yes it's FF and they can send a tech out but they want to remove the foam and watch it in there shop for a couple of days just in case it's not where they think the leak is, what is common practice from dealers with leaking tubs in the first week??
