Original => Hot Tub Forum => Topic started by: Circlt on April 20, 2005, 01:27:53 am
Nice forum, just stumbled on it while searching for quality dealers in my area, Southern California.
My husband and I are looking to buy our first spa. We have had some "hand-me-downs" but we want to buy a quality spa and although I want value I am more concerned with technology.
Having read this board I know that first we need to consider what our use will be and that is primarily hydrotherapy for our small family (particularly for his neck) but we also have a well and the water is terrible. We live on a river, and there are numerous minerals/deposits and other unwanteds in our water. The sewage treatment plant is just a mile upstream. They dump it into a wetlands after treatment and our well is just on the backside of the last wetland pond. Enough said. That is the table we draw from. I know from our indoor facilities that the water is extremely hard on components....faucets clog up over time, hard water rusted deposits and stains are constant. Add to that we live in a high dust and debris zone (dirt roads and lots of trees that drop seeds and other debris). I know a cover will help but if we use the spa as much as we hope, we can not avoid the high probability of dirt, debris, and poor water quality filtering thru the spa. I don't want to have to constantly treat/drain/clean so if there is a technology out there by a manufacturer that is well suited to this type of environment, I would be interested. Please note that I want a quality spa and I am also interested in quality in other areas, but this is one area where I know I absolutely can not cut corners or I will be paying for it over time.
I am not a techie and I am having a very hard time understanding the filtration systems. It's more than just what kind of filter you have, it seems to also incorporate circulation and pumps, and whether they run 24/7 and also what effect the various filter locations have on the heating unit (or this could be my poor interpretation). It also seems that when discussions on this topic are had, monthly cost is discussed in terms of energy consumption. I would much rather pay a little more monthly for the right system rather than burn out a pump, corrode my jets, etc. or have overly frequent filter replacements or chemical costs. I don't know what the right balance is but you techs can probably see this more clearly than I.
Incidentally we looked at Sundance today, very impressed with the tub, (Majesta) but I don't understand the differences in technology. We will check out Hot Springs next. Open to other manufacturers if you recommend them for filtration/circulation. If someone out there could explain in simple layman's terms what the main differences are in the major filtration/circulation systems are, I could possibly make an informed decision. As it is, I can't even read the technology page of Sundance's website, as the main drool won't display on the page properly.
Many thanks and I will be a regular lurker from now on.
(P.S. If you are wondering why we put up with the water, we live on a wildlife preserve of 1500 acres so it's one of those things you learn to live with in exchange for the pluses). : )
Also as an added thought, the dealer (I won't mention him by name) was extremely reasonable and he was the first one we dealt with. After reading this board I am 100% confident he was offering a good deal. I just don't know if it is the right tub for us. Another thing that concerned me is that Sundance tubs are 'full foam" according to this dealer....I thought that was frowned on? Perhaps I should do a little more research on that. I did like the warranty so perhaps it is a moot point.
Welcome Circit!
I don't know if I can help with the filtration issue. I am not a techie either, but the major manufacturers all keep the water clean. That is the important part. Whether it is filtering cycles that are programmed, or a constant circulation pump for filtration, both systems work! How well they work for your water issues, that will be for the experts to determine! I would suggest narrowing down to a couple of tubs (manufacturers/dealers) and taking a sample for them to test. Maybe the local guys and gals would have a suggestion for you.
As to full foam, don't sweat that. If it is by a good maker, and has a reliable dealer in your area, don't worry! Especially since you are in Southern California! There are lots of great tubs out there, Sundance is one of the manufacturers that makes them, HotSpring is another. What other brands do you have available in your area? You may want to check out Marquis, Artesian, LA Spas, Dynasty, Caldera, uhhhhh...sorry if I missed any. These are in no particular order, just a list off the top of my head!
Good luck!!
Circlt, welcome to the web. First, you need to be aware I am a dealer, we have been handling the same brand for the last 16 years and there is a reason for that. That may lead you to believe that I am opinionated, but I believe it to be experienced with 21 years of being a dealer. The first 5 years of handling good, better, best categories was the education period.
I would recommend that you focus on SD, the filtration and the use of ozone in conjunction with water maintenance that would reduce the use of chemicals and increase the length of time between water changes.
All other spas are good and worthy of your consideration. You would most likely enjoy any one of them as they will all produce seemingly similar results to a good hot water soak.
Over the 16 years, our customers have had very good experience using ozone to substantially reduce the dependency on chemical sanitizers. While this is not the focus of your post, I would only want to indicate that SD would be a best choice in the good, better, best catergory.
However, you are the person to make that judgement.
If you have specific questions, I would be glad to respond.
Welcome! Evaluating spas can be overwhelming at first ???. Just take your time, ask questions both here and at the dealers and you will soon be debating the merits of full-foam (which isn't necessarily a bad thing by the way) and thermal-loc insultation, 24/7 circulation pumps vs multiple filter cycles, loungers, and ranking various manufacturers :P. IMO, you will find that if you stay with the big names, the technology differences are more marketing hype :o than substance (they all provide clean water and good hydrotherapy, they just use different ways to get there), and you pay similar prices for similar products. That isn't to say that there won't be one "perfect" tub for your situation, you just have to learn enough to know what that is. Shopping dealers and wet testing is part of that, so is spending some time on this site, rhtubs.com (which has some valuable overviews and FAQ sections) and other forums. There is a search feature here that will help you find previous discussions of most topics, just make sure to adjust the search period to include a good chunk of time.
Regarding your water. It sounds like your house should be plumbed to make sure that all the water including toilets and outside faucets is treated by filters and/or softener, if it isn't already. If so, be careful regarding softened water in your tub, consult your dealer. As Lori suggested, a local dealer may have already helped others with similar water, and have a procedure that will address your concerns. Bring a sample of the water you will use to fill the tub to the dealer for testing. FYI, there are chemical tools to deal with almost any water issue and hose-end filters available to use when filling your tub. If worse comes to worse, some areas have water services that will deliver hot, balanced and sanitized water to fill your tub for a fee ($150 here).
My first thought is not to worry too much about the dust and dirt in the air. You will only have the cover off an hour or so a day, and usually during quiet periods. However, if I'm wrong and it truly will be an issue, you may have to become an expert on spa filtration techniques after all :P. There are a lot of approaches to filtration and they all seem to work as far as maintaining clean water, but one may fit your situation better. There was a good discussion on filtration here a couple of months ago. Search back and see if you can find it. The point that stuck with me was the distincton that "100%/no bypass filtration" of the water passing through the pumps still doesn't mean that all of the water in the tub gets filtered, because water still comes in from the upper zone of the tub and there are spots lower in the tub where things can settle out. However, in an environment like yours "100% filtration" would at least ensure protection for your pumps. You will also need to consider filter media, and its effect on maintenance. It could be that in your environment, one type of filter may be better due to concerns about particle size, plugging, cleaning and replacement costs. As I'm writing this, it dawns on me that Hot Spring's approach to filtration with "no bypass" and their dishwasher-cleanable TriX filters, and Hydropool's floor cleaning feature may be a choices you should give extra consideration to.
Good luck!
Crclt,
There are some SoCal dealer who are regulars on this board and can maybe enev help you locally if you're more specific relative to your area in SoCal.
Circlt,
I live in San Antonio which has extremely hard water due to all the limestone here. Most of the folks I know use a water softener that treats the "clogging" due to buildup.
We are installing one in the home that we are building that should be completed in July.
A thought on water softeners though...you probably do not want to run your softened water to an outside spigot that you will be watering your lawn with. This was advised against by the local nursery, home store, builder, neighbors...you name it. There are minute amts of salt (or potassium depending on what you use to soften the water) that will go out in that water and could hurt your lawn/plants. It may be different for your case though.
As far as filtration goes...all the vendors that I have researched have quality water filtration systems (HS, Marquis, Caldera, Artesian, Sundance, D1).
I am not sure how hard it would be in your particular case to go the water softener route. Another thought may be to use a good quality prefilter when filling your tub up...just a thought. Most dealers sell these.
And you can also ask your dealer in the area what their thoughts are!
Good Luck! :)
...I would recommend that you focus on SD, the filtration and the use of ozone in conjunction with water maintenance that would reduce the use of chemicals and increase the length of time between water changes. ...
...Over the 16 years, our customers have had very good experience using ozone to substantially reduce the dependency on chemical sanitizers. While this is not the focus of your post, I would only want to indicate that SD would be a best choice in the good, better, best catergory. ...
J McD, not to pick nits, but I'm a little concerned that this post makes it sound like Sundance is one of the only manufacturers using ozone as part of their clean water system. I'm sure that isn't what you intended, since we all know that isn't true, but a new shopper may not.
I also take issue with the implication that ozone is benign and not a "chemical" with its own set of benefits and risks, but that also is a topic for another thread, which quite frankly has already been done. I know this makes it sound like I am "anti-ozone" -- I'm not. I personally am ambivalent about ozone use in hot tubs, (except my previously stated concerns regarding indoor air quality :P) I see its potential benefits, particularly the ability to reduce other sanitizer use, and the 24/7 sanitation/oxidation to help maintain the water when users are away a few days, or forget to sanitize -- but also see maintenance costs, including bulbs/chips and the pillows and covers attacked by ozone and other chemicals-- offgassing controls or not. I just worry that some manufacturers and dealers present it in manner that oversteps what little scientific research is available on the subject, and overstates the benefits while ignoring the drawbacks. I know that's marketing in America, but thought this board was supposed to be more balanced.
I really don't want to start another version of the "Ozone Wars", especially not in this thread, since it is not an issue that Circlt identified as a concern, and a reprise would not do anything to assist their search for a spa. Just my two cents.
Soakin
p.s. Moderators, is there a way to quote a post, but start a new thread with it, so as to avoid highjacking threads and starting down a path that is off topic?
I also take issue with the implication that ozone is benign and not a "chemical" with its own set of benefits and risks, but that also is a topic for another thread, which quite frankly has already been done. I know this makes it sound like I am "anti-ozone". I'm not, I personally am ambivalent about ozone use in hot tubs, (except my previously stated concerns regarding indoor air quality :P) and think it may hold promise. I just worry that some manufacturers and dealers present it in manner that oversteps what little scientific research is available on the subject.
Soakin
Soakin,
I would take more issue that J Mcd is professing that sundance is the only manufacturer to focus on as they are the best in the good, better, best category. All other spas are good and worthy of consideration however, cant hold a candle to the best :o Just playin with ya J Mcd ;D
Thank you all, what a nice group, and I appreciate dealer advice since you know how your product performs and why.
I am in Riverside. I plan on wet testing all the tubs but as one of you said, there is more to it than just hot water and jets. Fantastic suggestion bringing a water sample to the dealer!!! Would not have thought of that.
I do like the SD 880 line. Would that filtration be considered "100% filtration" since it has a circulation pump that is always on? Also, do the 880's come with Ozonator already in them or is that extra? I know the CD Ozonator is extra but I thought that was above and beyond an ozonator already in the system. (Could be I listened wrong). How long does that CD ozonator last and what does it cost initially and then to replace? If I add the CD, what maintenance would I still do? Is it true that if I have a CD ozonator, then I would not be a candidate for BaquaSPa, but use chlorine instead? I understand fewer chemicals with ozonator but what about foam and scum, does the ozonator control that too? (stuff that comes from your oils in your skin, etc)
A hose filter, what a great idea!!!! I do not have a water softener and did read that thread about soft water but a hose filter is a great idea.
I don't understand the microclean filter, is it one filter or two (and which of those is disposable vs. cleanable?) I saw the filter and it had sort of a blue plastic cage around a pleated paper filter but that was one piece, I thought. The dealer said the cage is to prevent the paper from falling apart. So I'm not sure what part is disposable? I don't mind cleaning filters either. I think I read somewhere that just because the 880 comes with that blue cage filter doesn't mean you can't use the other kind but I'm not sure why anyone would want the older filter technology? Is one disposable and the other isn't? Can you clean the disposables or do they fall apart?
I read the thread about charging for warranty service calls. I don't know about my dealer, will have to ask and I will also want to review the warranty contract up front before I buy. I don't mind if it is disclosed up front but what happened to that one man with his new Optima was really a cheap shot that should have been withdrawn by the dealer when confronted with the discrepency, along with profuse apologies. Opportunity lost and damage done. I reviewed the warranties on line between Sundance and HS and they appear to be the same.....SD goes a little longer on shell defect. I did not see anything there about service fees but as I recall they were directly dealer related in that scenario.
I have not seen HS tubs yet. I was first attracted to them because they sell refurbs but now I am smarter from reading this board and realize I need a good warranty and I don't think I get one on a used spa. (At least it doesn't say anything on the website). How is their filtration technology different from SD? Don't they also offer a circ pump, filter and ozonator? I know they advertise "no bypass" but I think I would get that in SD too, right?
Just one other question, what is usually the first component to "quit" on a spa ....in other words, what reasonable expectation should I have about my first replacement, and when?
I would take more issue that J Mcd is professing that sundance is the only manufacturer to focus on as they are the best in the good, better, best category. All other spas are good and worthy of consideration however, cant hold a candle to the best :o ;D
Just to show how fair and balanced I am 8), I gave him the benefit of the doubt on that one. It took a little interpretation, but I read it as SD is one of the "best:. Not sure if your brand is a "better" or "best" in his book, you two can work that one out. I guess my ozone fuse is just a little short! ;D
....I do like the SD 880 line. Would that filtration be considered "100% filtration" since it has a circulation pump that is always on? ... I have not seen HS tubs yet. ... How is their filtration technology different from SD? Don't they also offer a circ pump, filter and ozonator? I know they advertise "no bypass" but I think I would get that in SD too, right?
... I do not have a water softener...
I really suggest you search "100% filtration" to find the discussion of what that really means, but suffice it to say, just because your circ pump moves more gallons through a filter in a day than the capacity of the tub, that is not really "100% filtration", and it certainly is not "no bypass". I hear a thunder of Hot Spring hooves coming around the corner to explain their filtration system, so I'll just say that I don't think they will agree you are getting the same filtration on a SD. You have to decide if the differences are important, but as I said before: all of the good manufaturers filter enough water to maintain a clean tub, but if the dusty environment is an issue, "no bypass" might be worth considering as pump protection, as is the Hydropool floor cleaning feature as a way to keep grit off the bottom.
Re: water softener. As I said before, with the problems you describe with your water, I would think a softener or whole house filtration system would be mandatory. Cheap shot coming: perhaps J McD could recommend at good ozone water purification system. ;D (Really sorry, I just couldn't help myself!)
Rollin, rollin, rollin.....RAWHIDE!
The big advantage to our 100% no-bypass filtration is that every drop of water is filtered BEFORE it ever enters the pump, the heater, the plumbing. To my knowledge, no one else does it this way. Feel free to correct me if I'm mistaken. I'm always looking to learn more about this wonderful industry.
Terminator
Terminator
According to the brochure, "Only Mother Nature Does It Better" ;) That was for JA ;D
Wow I just looked at the Marquis filtration system on the website. Impressive! I will try those tubs as well. Is there any truth though that you can't run all the jets at the same time? Someone on this board was not happy with their Marquis for that reason. (Though doesn't hate it as much as at first.)
HS Hooves and all, I do see your point about all of the water going through the filter. I will search the board for other threads on that debate so no need to do it again here. Thanks for getting me in the right direction, you guys are great. I think J McD is right, many of the tubs have good qualities and it will probably be a very competitive search. Right behind filtration is the importance of a solid dealer who will back up the sale with service.
By the way, installing a water softener is not an option for us. Also, if we retire and move, how hard is it to move a spa?
I have to agree... what in the world did Sundance do to its web site. They used to have a pretty good site...now..forget it. Not to mention what they did to the Jacuzzi Premium site.
The Sundance 880 series now uses a high volume circ pump that handles all of its filtering through a new one part micro clean filter that is disposable after six months to a year (depending upon who you talk to or use). The therapy pumps are now both one speed and are exclusive of the filter system (except for the little socks if you count them). There is a new waterfall system that works through the circ pump.
The Sundance CD ozonator does not require chip replacement and from what I hear should last ten years. You may need to replace the plastic tubing and/or check valves periodically, but this something any end user can do. All Sundance spas come ozone ready, but the ozonator is extra and dealer installed.
The next series down, the 800 series uses the older style two part filter with a low volume circ pump and filter cylcles using a two speed therapy pump. One filter is the small micro clean filter serviced by the circ pump and is diposed of after three or four months. The other filter is a pleated filter run that should be cleaned monthly.
Boy, this is really a tough crowd, after all of the openess and disclaimers, trying NOT to be subject to attack.
Circlt indicates that she has looked at - A - spa which happens to be the one I referenced, suggesting that she focus on filtration and purification because of her water situation.
The real problem here is water quality and the time between water changes, not which spa is better than the other, or what is the best method to maintain water, but under her conditions, I sure wouldn't want to sit in a chemical stew or change the water every other month.
Purifying the water is one issue, keeping it clean is another issue, and the time frame between water changes is again still another issue.
I do not mean to offend anyone, trip any triggers, pontificate or espouse any particular this or that in my attempt to be open and honest, but yet, I am seemingly offensive to some in my statement that was meant to be helpful.
Cheeze, some of you really have a chip on your shoulder, looking to draw a line in the sand and debate an issue here.
I know what I know and what I have learned over time based on my hands on experience of 21 years. Yet, I still learn something new everyday. I am not here to profit or to stand on a soap box.
If I have offended any of you, then I appologize to you, but YOU are not dealing with her problem, but seemingly trying to stir one up.
If one can regognize that ozone, which is not a chemical but a gaseous form of sanitizer/oxidizer that does not build up or accumulate, does in fact have a POTENTIAL benefit particularly in the ability to reduce other chemical sanitizers that will in fact aid in the water purification then the point is made. It does have a particular application in this instance.
I am not looking to market one concept over the other, but if it CAN make the difference of longer term durations between water changes, it is absolutely appropriate.
Circlt is a newbie and look at us, were bickering again.
SD has had it's own problems during it's developement, and so has HS, D1, Mar, Col, and every other mfg in the industry and no one knows them better than the people in the industry that have handled them. We speak from experinece and we do have meaningful insight and benefit to those of you who are shopping to buy 1 spa when some of us have bought thousands.
You have made statements regarding what I have said when I never said anything about candles in my good, better, best scenario, so you individually speculate on my meanings and intentions.
But, for a newbie, if they are looking at 1 of the many other "best's", they should at least be able to focus on a feature and see if it is adequately represented in an alternate choice.
Let's get this right, THE BEST SPA IS THE ONE YOU'RE SITTING IN TONIGHT.
Boy, this is really a tough crowd...
It appears I offended you, so I apologize. It really was intended to be in fun -- but also to provide another point of view to your championing of ozone. Contrary to your opinion, I was trying to help Circlt on this and other issues, and hope I didn't just muddy the water. Almost all of us are on here to learn and try to help where we can. Just because we disagree doesn't mean we can't have fun.
I am leaving town for a few days so the ozone floor is yours (unless Doc is around to keep you in line ;D) Keep those bubbles coming!
Hey guys, you sure know how to get a thread going! Frankly, all the banter is what makes this a valuable board.
Thank you J. McD, for all your help. I have read all of your posts in other threads as well and you definitely give a fair, common sense approach. It didn't take me long to agree with you regarding the ozonator; the benefits far outweigh the cons and I am definitely going to want a CD in my spa, given the circumstances. Thanks for helping me spot that. Ozone is not for everybody and at least I understand the downside going in. I read your advice EXACTLY as you meant it.
Tony caught on to my dilemna in understanding Sundance filters, I am looking at websites trying to understand technology between the manufacturers and SD has a poor effort there compared to others.
There is a frequent poster on this board who loves his Grandee and has made some very good points about the five filter system of HS spas, in addition to the fact that their system is 100% no bypass, (which by the way, is a nice point but I think even 95% is still good) and I like the fact that the filters seem to have such a long life. Disposables concern me. I am sure that with my water and dust, the filter will take a significant beating. Having more than one filter at play seems to be a good idea in my case.
Marquis boasts a good filtration system and I plan to look into it. That diagram is scary, what the heck are spinners for, anyway? Any comments pro or con are welcome.
You all did me some good, bickering. It helps me feel confident I am going to be able to weigh things well, since you all made your point. I would much rather have all the advice I can get and be able to toss out what doesn't suit me rather than not be able to weigh it at all. This board is awesome and all of you are appreciated for taking the time to post. Now leave J. McD alone, he isn't the reason I already saw the SD first, it just happened to be closest. I will evaluate them all, believe me, and keep you posted. Hide and watch!
Are you aware that Mother Nature does not use any chemicals at all, and does in fact use Ozone exclusively.
Soakin, pull up on the stick, you didn't offend me, you misunderstood me. I accept your appology, if you accept mine. I wasn't a cheap shot, just a loving jab.
The points we make together stir up the issue and cause the truth to come to the surface. If we disagree, that means we're learning something and we need to challenge the issue to verify it's credibility. While each of us MAY think we're right about different things, we have both been wrong before, just like Doc. Now, don't go tell him I said that and start trouble all over again.
I don't consider myself to be a champion of ozone, but I do understand it and I have a long history of customer applications to draw from. In 21 years, I have never delivered a spa without ozone, so I am well aquainted with them and I guess you could say I am passionate about the subject that is very much debated, misunderstood and maligned. Your just trying to keep me honest aren't you.
I think we're both tuned into the same channel, we're just getting accquainted. Now let's have some more fun while we help others and maintain a well balanced forum. We're all here to help, if we wanted to be arrogant and pompous, well, we all know that position is taken.
So you're leavin town, eh, at least I don't have to tell you to get out of town. Fly or drive safe and we will await your safe return.
Circlt.......
Be advised...I know of NO spa on the market that can guarantee that 100% of the water gets filtered.
The only way that 100% of the water in the spa could be guaranteed to be filtered would be to have ALL of the water pass through the filter as in a closed loop system.
HS, while a very good filter, only states that 100% of the water that passes through the pumps is filtered. That is a correct statement.
I personally think the HS filter system is very nice but if you dont really take a good look at what they are stating then you could misunderstand what they are getting at.
The other filter systems work well also.
As far as Sundance goes...they are one of our leaders in choice when we purchase. This year they have gone to a disposable filter. You can use the "older ones" (last years filters) in the 05 Models if you so choose.
I will say this though....after looking at numerous spa's and wet testing a bunch. EACH DEALER we spoke with and researched had very good filtration. I would be comfortable with any of the filtration systems on the market from SD, D1, Sundance, Artesian, Marquis, Caldera. (havent had the chance to see arctic...yet!)
If ya have more ????'s let us know! I will be wet testing a Sundance Cameo Thurs night so if you have questions for Sundance lemme know and Ill ask our dealer here too!
Regards,
mike :)
Terminator
la spas also filters 100% of the water entering the heater, pump etc... They have a filter system called Aqua Kleen- interesting concept. It will filter particles down to 20 microns, and allows 4 times the flow rate of a cartridge filter.
What spinners are you speaking of....Also spas that use a circ pump yet have a manual clean up cycle do not filter the spa 100%... the water that is in the larger ...most cases 2" plumbing line does not get filtered until the jets are turned on ....some spas will purge those lines during set times though out the day....
Circlt,
If you stay with any of the major manufacturers, you will get a spa with a filtration system that works properly and keeps your water clean.....if you maintain it properly. All of this 100% filtration stuff is proprietary marketing. The most important part of tub sanitation is the owner.
Forget the type of insulation....forget the type of filtration....forget the number of pumps/jets....stick with a major manufacturer and concentrate on the therapy of the tub and the reputation of the dealer from which you buy. Let your wet tests decide which spa is better for you and enjoy your search. I did and I can't be happier with my MasterSpas LSX. Good luck. 8)
I went to their website to study this and couldn't find any information. I'm curious to know how they can do this when it looks like every spa they have has by-pass valves. By-pass valves, by design, by-pass the filter.
Maybe I'm ignorant but I see many companies claim to filter 100% of the water, yet their spas all have by-pass valves and only 1 or 2 filters. What am I missing? What is the purpose of the by-pass valves? Just trying to learn something new.
Terminator
I was just playin with ya too J Mcd. And there's nothin like the smell of ozone in the morning. ;)
Wasn't that from Apocalypse Now? ;D
si' :D
Terminator
pump 1 (heat and filter pump, as well as circ pump) draws all of it's water through 2 aqua kleen filters, this is the only way it gets water. Pump 2 draws from a suction fitting in the footwell and one filter. Pump 3 draws strickly from suction fittings in footwell. Good deal if you only have one or two pumps!
Not to split hairs, but since the suction fittings (by-pass valves) connect directly to the pump with no filter in between, by definition, they do not have 100% no by-pass filtration.
Terminator
Terminator
I was not insinuating that all pumps have 100% filtration. Your original post simply stated that all the water entering the pump, heater, and plumbing went through the filter. The same is the case with LA Spas.
That's fine by me! ;D
Terminator
circlt,
Well you sure got some of the pros going.
This is my take on the whole filtration thing...If there were one design that out preformed every other design...everyone would be using it. That being said some manufactureres may use meathods that may make your life easier based on the amount of trees you have in your area.
I don't know if you have a Coleman dealer in your area but if you do take a look.
I can relate to the tree shedding problem you experience. My yard is an acre, and it has over 40 trees on it. In fact right now there are three different types losing pine needles, sticky sap pods, and fuzzy catapillars like blooms full of purple pollen. ( gotta love springtime )
Coleman spas have a skimmer basket that sits above the big filter. This will catch up to 95% of the debree that you'll be trying to wash out of the pleats of the filters of other hottubs that don't have a skimmer system.
They also have a first filter that is easy to put in and it sits on top of the skimmer basket for times you want to filter down to a tighter micron than any pleated filter can. The times I use mine would be when a dirt cloud blows by while you're in the spa or if you're had a heavy bather load with suntan lotion or bug lotion on. You just pop that little inexpensive easy to install, flat first filter in and catch up to 99% of debee before it goes to the big filter.
The first filter can easily be used at you discretion and rinsed out under the sink and reused many many times. The first filter will extend the life of the big filter because it's not getting the wear and tear of a filter that is in direct contact with the debree. When it starts to ball up and get loose you can feel guilt free in throwing it away because they come two to a pack for arounf $19.00
Coleman Spas also have 100% filtration in that they draw all water over the filter both top and bottom. 70% surface water and 30% bottom water (taken in through the intakes on the bottom of the spa which do not need to have spa socks on them.)
It's all about easily acheiving the best water quality with the smallest amount of effert on your part. When you're watching all those wonderful trees lose all that stuff in every season, try to imagine digging that out of a wet pleated paper filter,yuk!
I also think you need to wet test any spa you're interested in. You may feel the technology you choose makes the most sense to you, but if you don't fit in that spa, or float like an icecube out of every seat....you'll forget what those great selling points were and will be much more likely to experience buyers remorse :'( The worst call any dealer can get is right after the first soak when the spa doesn't fit or the therapy isn't what you wanted because no wet test was done...
Spahappy :D
All this filtration talk has made me hungry....ummm....anyone for a full foam burger w/ extra closed cell or will it be the thermal lock dog hold the R-Value ;D
I prefer substance instead of junk food....
You know you are what you eat! ;)
Spahappy :D
Spahappy :D
I feel myself turning into mushroom barely soup as we speak. ;D
