Original => Hot Tub Forum => Topic started by: stumper66 on September 19, 2020, 04:22:31 pm
Title: Imagespa - Replaced the board, now no motors or light
Post by: stumper66 on September 19, 2020, 04:22:31 pm
I have an Imagespa with Balboa: 2000LE, ICON31 board.
Everything was working fine except for the heater.  I bought a replacement heater but still no heat.  Checked voltage at the heater and found no voltage, so I figured perhaps the board is not good, so I got a new board off ebay: https://www.ebay.com/itm/164375879685?nordt=true&orig_cvip=true&rt=nc&_trksid=p2546137.m43663.l10137
I swapped in the board and made sure everything is plugged in exactly as it was.
When I turned on the power, the control panel seems normal, it boots up with a 0, then shows the set temperature and actual temperature.  However the motors won't go (has two pumps).
When I press pump 1 I see the light under it go on but no action.  Same for pump 2 and the light.  However not even the light goes on.  I also notice I don't hear any relay clicking like I did with the old board.  Previously soon as I turn on the power I can hear a click.  Dead silence with this one.
I feel like there is a common relay or something that is not working or not connected that is causing everything to not switch on.
Ideas?
Title: Re: Imagespa - Replaced the board, now no motors or light
Post by: CanadianSpaTech on September 20, 2020, 07:13:16 pm
You would have to post photos of the circuit board and also the inside cover with the schematic on it.
Post by: stumper66 on September 20, 2020, 07:31:03 pm
old board after removal:
https://ibb.co/JkJ5dZF
schematic (unfortunately some paint is covering some of it):
https://ibb.co/LhCNZ7z
new board installed:
https://ibb.co/xDWfvNR
Post by: CanadianSpaTech on September 21, 2020, 07:32:45 am
Are the 2 big buss fuses (SC25 or SC30 on them) top left from the original board. They protect the pumps and the pumps won't run if they are blown. Have you tested them?
Post by: stumper66 on September 21, 2020, 09:52:58 am
No I didn't transfer anything over from the old board.  All fuses were included.
I checked for continuity on all fuses and all were good.
Post by: stumper66 on September 21, 2020, 07:30:53 pm
Something really strange.
I took my volt meter and unplugged pump 2.  It shows 250v regardless of if it shows pump2 on or not.
Same with pump1 high.  However pump1 low didn't register anything.
How can it be showing voltage where the pump plugs in yet there is no motor activity?
Post by: CanadianSpaTech on September 22, 2020, 08:21:25 am
On the top right of the board there is a red block S1 or Switchbank 1 with white up/down switches 1-9 do they match the original settings?
Post by: stumper66 on September 23, 2020, 10:18:11 am
Yes all dipswitch settings match the old one.
