Original => Hot Tub Forum => Topic started by: brian_tr on March 30, 2018, 05:50:08 pm
I have what I thought was a 2002 Sundance Cameo. Finally going to have to give in and get a new cover after repairing the hinge a few times. Been glued to many times. Cover measures 91" which sites say is a 2000 model. Anyhow thinking of getting it from the spa depot. Would like to get a new lift that is easier on the hinge. Any suggestions?
Depending on the clearance you have behind the spa, I would use either a Covermate 1 or Covermate 2 from Leisure Concepts. My only concern is I thought Leisure Concepts has special brackets for Sundance due to the corner radius. I'm not sure if the standard Covermate 1 would work or if you have to have the Sundance brackets.
