Brand Specific Forums => Hot Spring Spas => Topic started by: ridge on October 02, 2016, 07:47:40 am
Title: Hot Spot Tempo
Post by: ridge on October 02, 2016, 07:47:40 am
We have our Tempo filter settings on f1 and f2 to run 3 hrs and then shut off and it worked correct for a week and now it comes on when it should but does not shut off, it will be warranty but has anyone had that happen?
Title: Re: Hot Spot Tempo
Post by: Hottubguy on October 02, 2016, 09:23:27 pm
It's not calling for heat is it?
Post by: ridge on October 03, 2016, 05:37:18 am
I am not sure what was going on, it should shut off approx. 6:15 am and 6:15pm, my wife said it was still running when she left for work at 7:30am, that night I checked and it was running still at 7pm, not sure what was going on and now this weekend it worked like it should? I wanted to see if others seen this issue.
Post by: Hottubguy on October 03, 2016, 07:23:21 pm
Was the temp at what it was set for?  It could be running becuase it was in heating mode
Post by: hottubdan on October 04, 2016, 10:08:29 pm
Contact your dealer.  I think you need a software update.
Post by: ridge on October 05, 2016, 05:28:25 am
I went out last night about a hr after it shut of been shut off, opened cover and the f1 was not on so it should of been shut off but I forgot to look at the temp to see if heater was making it run, so I will watch again tonight.
