Brand Specific Forums => Hot Spring Spas => Topic started by: griffj17 on December 08, 2015, 09:11:30 am
I walked outside this morning to run my hot tub on the clean cycle. I noticed the gfci was tripped. I reset it and there's no power to the hot tub. I replaced the circuit board to it back in the summer and haven't had any issues until today. Can someone let me know what maybe going with this...
Update.
As soon as I put a tester on it. It trips the gfci.
Still having issues if anyone can help me out. Replaced the gfci, replaced the power cord. Tub starts to cycle and then trips the gfci.
faulty board, faulty heater, faulty circ pump, could be a number of things, do you have access to a volt meter? and do you know how to use it? if not it might be best to call a repair company to come look at it
Not what you want to hear, but it's pretty hard to troubleshoot when there's so little information. A pro will understand the steps and get this resolved quickly for you.
I think I finally figured it out. I disconnected the high limit switches and the circulator kicked on withought tripping the gfci. The reset wasn't tripped so I'm guessing the heater is bad.
