Original => Hot Tub Forum => Topic started by: cars30 on July 16, 2015, 10:03:37 am
hi i have a temp light flashing i did the filter check by takeing out and running .no difference.circulation pump is moveing water a steady flow comeing out return.pump seems to be running at a low speed but is pumping.not sure how fast pump should be running.i changed the pressure switch and a new cable .what i did notice is my temp display on controler is stuck at 50 degress and tub water from sun is at 80 degress does it sound like a temp sensor
Start by turning the power off and unplug the sensors from the circuit board and then plug them back in. That will ensure that the sensors are plugged in properly - eliminating this as a possible cause. Then turn the spa back on.
